#751 |
Re: my 65 fleetside build
If you ever decide to come over to Huntsville and race hit me up. I would like to meet you and see your truck in person.
Looking forward to more updates
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
#752 |
![]() Join Date: Mar 2013
Looking really nice!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#753 | ||||
your welcome and thanks.
thanks T.J.
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
#754 |
we've got a few more things to get iron out and then back to work on the truck. Other than that it's great to be back home.
#755 |
Checkin in on that new tire roasting motor.
#756 |
went last night to the local test and tune, installed a set of m/t pro drag radials and went a 7.10 at 95.62 mph. I think with a little more tuning I might get a high 6 out of it. love the m/t cot a 1.5 60 foot, think its pulling the left tire a little
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion Last edited by flips72; 11-14-2015 at 07:31 PM. |
#757 |
1 thing at a time is progress.
Wish mine would tote a tire. Haha
Alan
Philippians 2:14-16 |
#758 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Very nice!!!
I could tell a while back that a tire in the air was in the not so far future!!! Weather it was to come from a blue bottle or a different motor I knew that it was very close by! Nice job!!!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
#759 |
we posted a few videos on you tube at the dragstrip, just type in flips72 and they will come up, I think there is 4 of them, we tried to put them on here but didn't have any luck. hope you enjoy them bomp.
#760 |
Nice, Very Nice!!!
Sounds Awesome, & launchin' pretty good!
#761 |
Rollin' Old Skool
x2! Not only does it look good, but it really goes too.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#762 |
truck is flying and looks great as well.those moter or n2o passes?Either way it is hauling
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
#763 |
Looks and sounds great.
Alan
#764 |
Wow!!
You've got that truck DIALED IN Blowin off the competitions doors. And they thought they had a chance. ha |
#765 | |||
bring it up here and well throw a little blue bottle in the back
![]() Quote:
#766 | |
Nice concept, I like!!!
#767 |
truck sounds awesome! looks like you treed them all too, now that is really awesome!!
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
#768 |
Ok.... I dug back through because I couldn't remember the specifics.
What are the specs on the motor/drivetrain?
#769 | ||
![]() Quote:
406, gm 4 bolt block studded mains, scat 4340 crank, scat i beam 4340 rods with 7/16 cap bolts, keith black icon forged pistons, king bearings, total seal rings, lunati solid roller 626 lift with a 109 lobe seperation, double roller timimg set with torington bearing, cloyes timing cover with adjustable cam button, dart pro 1 with 215 runners, 205 160 valves, comp push rods, comp gold series rockers, victor jr intake with a stealth performance worked 750 mighty demon, cheater nitrous kit, msd 6al digital ignition with billet dist, and msd dry coil, trans is a turbo 350, kolene steeles and red clutches, hardened sprag and a tci super street fighter stall with baloon plates, 3 1/2 inch driveshaft with 1350 spicer joints and a truck 12 bolt with factory posi, 411 usa gears and strange girdle and moser 1350 yoke. stock suspension with the exception of drop springs and spindles. i think that about covers it.
#770 |
Nice combo!
I never realized this was a go-fast ride.
#771 |
thanks scoti, i have always been a hot rodder at heart, i might be going to tame it down some this winter and go ls fuel injected with ac. i have a rough 66 bbw thats itching for the go fast goodies and i can lighten it up alot, where i dont want to mess with the red truck to much, but its going to be hard to support two projects at once and then the wife is wanting a first gen camaro to top it all off.
#772 |
Flip, in my opinion, you should build the 1st gen Camaro for your wife first, if you want to go fast for cheap anyway!
On a side note, about a month or so ago, I rode in a friends '68 Camaro for the first time...A full tube frame, aluminum interior, Willwood brakes, four-link 9 inch, top notch, all-steel car...with a ZZ502 crate-motor that is basically stock except for cam, intake & dominator carb. the motor dyno'd at 576 h.p. and runs low 10's in the quarter...I know, hard to believe. Now I am not a drag racer, Have done it in a few cars that I have owned (LS-6 Chevelle, Buick Grand National and assorted Corvettes) But they were childs-play compared to this.... Nor am I up to speed with all of the electronic gadgetry, i.e trans-brake, rev-limiter b.s, electronic nitrous controls, etc, but I can truly tell you that ...Never, NEVER, have I experienced something so brutal as a launch in that car! HOLY-F! we did it several times on a country road, and I could sense the tire spin and smell the rubber from the 19.50 x 32 M&H Racemasters way past 100 m.p.h. Now I am not sayin that you need to make your wife's camaro that fast, but with some of your go-fast parts, it could be real healthy, and you could go LS with the new racer truck! What are you thinkin about now? LOL!
#773 |
Flip, Would you mind telling me what color RED you used on your truck? Your build thread is really nice and like what you did with your truck and the stance.
#774 | ||
![]() Quote:
#775 |
just a quick peek at what followed me home today, another 65 bbw, thinking about building it for the wife, I will start a build thread shortly I hope, trying to build another shop for parking so I can get back in mine to work.
