Old 08-27-2014, 03:37 PM   #1
slammed90
slammed90's Avatar
non ac cab to ac cab
Ive got a 84 c20 basic model n only has hoses for heater...what would b the easiest way to convert it to having ac?...thnks in advance
"NO BAGS JUST PLAIN LOW"
slammed90 is offline   Reply With Quote
Old 08-27-2014, 05:21 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: non ac cab to ac cab
Can you post a pic of the box on the firewall?
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 08-27-2014, 07:44 PM   #3
slammed90
slammed90's Avatar
Ill take pics in a bit.
Old 08-27-2014, 08:52 PM   #4
farmall
farmall's Avatar
Im changing cabs. 81 rusty no option to 87 Silverado.
I was wondering if it possible to have the footwell vents and AC at the same time.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 08-27-2014, 09:31 PM   #5
slammed90
slammed90's Avatar
Old 08-27-2014, 09:31 PM   #6
slammed90
slammed90's Avatar
No box...hose goin to the radiator
Old 08-27-2014, 10:02 PM   #7
Just call me Sean
Non a/c firewall, just making sure. You would have to modify the firewall to put on a factory system. I wouldn't consider that too hard, but it does depend on your knowledge, available tools, and how much you care how it looks. Don't have any experience with aftermarket systems, probably would be easier but more expensive.
Old 08-28-2014, 02:08 AM   #8
slammed90
slammed90's Avatar
1200 was one of em aftermarket ones...with that kinda cash I'd rather put another cab on it...but cabs too clean to take off..
Old 08-28-2014, 02:09 AM   #9
slammed90
slammed90's Avatar
Would b the fastest n cleanest way though
Old 08-28-2014, 06:48 PM   #10
silverbear
silverbear's Avatar
My 86 started out as a non A/C cab. I pulled all the necessary components of off a blazer that was getting scraped so I could convert. The hole in the firewall is different and I started to make a pattern off of the Blazer firewall when I found a replacement cab with A/C. My original cab was more rust than good metal. To convert to the OEM setup it is a bit more than just swapping out the blower motor box in the engine bay. The controls are different. The manual kick panel vent setup on the pass. side get replaced with a vacuum actuator and there is an additional actuator and flap to install in the rain gutter on the passenger side.
Having said all of that, it would be cheaper to find OEM parts to convert with a little bit of cutting the firewall. The engine compartment looks much cleaner with a system like what Vintage Air offers. The V.A. system has a better blower motor but that system will hurt the wallet pretty bad.
86 Chevrolet K10 350/SM465 Frankie SOLD
1995 GMC Yukon GT SOLD
1996 GMC Yukon GT
2010 Suburban 1500 4x4 5.3l/6L80e. Sold
2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e
silverbear is offline   Reply With Quote
Old 08-28-2014, 09:38 PM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
leave in the manual kick vents,thats the back of the stock AC selector ,
close it off to the tee to the front
plug the line to the pass side,open and close both manualy.
should work
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-29-2014, 12:14 AM   #12
farmall
farmall's Avatar
Thanks!
Old 08-29-2014, 02:45 AM   #13
andrewmp6
Vintage air makes a kit its not cheap.But everything will be brand new and its a under dash unit so you have a smoother firewall.
