#1251 |
![]() Join Date: Mar 2012
Re: Crusty Rusty Leaky Squeaky 67 Step
With the tray in place, I started to weld in the first of the compressor mounts. I was having some minor issues with the MIG, so I stopped at about the halfway mark on the first mount. Lucky for me I did so. I'd revised the location of the mount without double checking for interference. When I set one of the compressors on it, BANG! I realized it wouldn't clear the cross sill.
So this morning I zipped the mount off the frame with a thin kerf cutting disc and went back with the mount like I'd originally planned. All is well now. Next up will be running air lines and wiring.
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
#1252 |
#1253 |
Neat and clean Vic, we wouldn't expect nothing else...
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
#1254 |
KILLIN' IT!!!
That all looks super nice Vic! Love them little bits you're milling for the ends of the tubular supports and the sheet metal work is really cool.
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
#1255 |
I feel lucky I get a birds eye view of Vic's work in progress as we prep parts for my engine rebuild that he is in the process of schooling me on. Great work Vic!
Scott |
#1256 |
Great stuff, stoked to see it!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#1257 |
It's been a busy couple of weeks working to get the air suspension operational for the Midwest All Truck Nationals yesterday. Chip (Low Elco) graciously offered to trailer the chassis out there behind his freshly lowered BBT (which looked awesome!). We had a great time hanging with other forum members, checking out all the fine rides, grillin' and downing some cold ones. With all that behind me, I can catch up on recent efforts.
After retooling the compressor mounts, the next hurdle was to locate the position sensors at each corner. In the back, I welded tabs to one of the tubes that support the air tank as well as to the trailing arms. Up front, I attached tabs under the frame rails for the sensor mount and used blind rivet nuts in the lower control arm tubes for the lower rod end mounts. Measured carefully and cut the links to length. It all sounds so easy when you say it fast. In reality, there was lots of head scratching between steps. McMaster-Carr had some neat clips for mounting the air line, so I popped for enough to do the job. They came with screws, but I opted to use little 3/32" pop rivets. I setup the lines to run inside the frame rails and curl around the back into the solenoid valve body. I'll use the Adel style clamps that came with the kit to keep them tucked up out of the way.
#1258 |
Up front, the cleanest way to get the line routed from the bag to the inside of the frame rail was by using a 90 degree bulkhead fitting. There was already a small hole in the crossmember where the fitting needed to go, so it served as a pilot hole for the size drill needed for the fitting. I then used a short section of hose from the bag to the fitting and connected the long line running to the back to the other end.
Plumbing the air tank was next on the list. I picked up some pre-made high pressure hoses and used them to remotely locate the water trap(s). There was only one included in the kit, and the other one won't be here until Tuesday, so I just temporarily made a splice with a union fitting. With the air lines all done, the only thing remaining was the wiring. It's pretty simple, but the biggest issue was all the excess. I just looped it up and used cable ties to organize it. I'll shorten them up later on when wiring the rest of the truck. I did some research on the plugs hoping I'd find a source for the pins so I won't have to cut and splice, but I haven't 100% nailed it yet. Pretty sure the plugs on the ECU are from Molex and the ends on the sensors are the unshrouded Delphi GT150 type. But more research is required. The system has an auto calibration feature and it went thru all that perfectly. When it finished, it set the ride height to the middle position. It has presets for low (10% travel), medium (50% travel), and high (90% travel). However, if you press the buttons to change it from the middle to the low or high positions, it does nothing. The manual buttons work perfectly to raise or lower the bags, either individually or in pairs. Reckon I'll call Travis at AZ Perf. this week and see if he has any insights. Meanwhile, I'll tear it all apart again to send the metal parts out for powder coating.
#1259 |
Very nice Vic.
Now that you got the air ride done what's next on the list? |
#1260 |
It got a lot of attention! It was fun to watch it go up and down. It drew a crowd the whole day. Glad you went with us, Vic and Kathy!
#1261 | ||
#1262 | |
You will have the cab whipped into shape in no time. |
#1263 |
That looks great Vic. I didn't realize how fast that system will launch the truck up in hurry.
Scott |
#1264 |
Whole air ride system is looking great Vic! Attention to detail is awesome!
#1265 |
This is all coming together really nicely. I really like the line clamps.
#1266 |
Just spotted the link to the Youtube vid. Awesome!
#1267 |
Since getting home from the Truck Nats, I've been busy assembling a 357 Magnum engine for Scott. The chassis has just been patiently waiting its turn and I knew it needed some TLC. I'd observed that the rear bags held air just fine, but the fronts would deflate in just a few hours. So before disassembling everything to prep my homemade mounts for powder coating, I did some investigating with dishwashing soap and water. The leaks were coming from the 90 degree bulkhead fittings. They're made by Parker and have no support tube in them like the KV2 series fittings from SMC. I looked high and low for a 90 bulkhead with the support tube, but had no luck.
An alternative solution is to use a bulkhead union with a 90 elbow fitting that has one end PTC (push to connect) and the other a straight leg that fits into the female end of the bulkhead. But further research revealed that the only KV2 series elbow was for 1/4" line ...and of course I have 3/8". What the vendors are selling are the 3/8" Parker elbows without the support tube. Why all the fretting over the support tube, you ask? Well, it appears that the tight bend radius is torqueing the tubing just enough to create a leak. So, the obvious solution is to make yer own! I had some leftover 90's with brass male 1/4 NPT on one end and KV2 PTC on the other. First step was to tap the id of the brass end to 1/8 NPT. Then I turned a brass 1/8 NPT close nipple to the dimensions I needed and assembled it using a R8 collet to keep from damaging the polished exterior. So I now have the KV2 style PTC's at every joint in the system. Hopefully it will solve the leak issues. When I get my parts back from the powder coater, I'll reassemble everything and report back.
#1268 |
Vic, you make things look so easy!!! Very nice job on the fittings, also great job on Scott's engine, it sure looks good. Anxious to see a video of it it when he gets it put in.
#1269 |
Tricky! I used to be in the pneumatics buiz (Festo) and have used a bunch of PTC fittings. I've never seen one with the support sleeve inside - nice! Guess I've been out of that game for a while. I've seen plugs turned from aluminum that are used to block off a PTC but always opted for the plastic ones in fear that the retractable barbs wouldn't "bite" into metal well enough. Have you tried to pull the brass tube you made out of a PTC? Never having played with a vehicle air ride setup before, curious what kind of pressures you're running?
#1270 | |
#1271 |
I'll have to say, he's pretty lucky to have a friend like you... I defiantly know he appreciates it.
#1272 | |
#1273 | |
#1274 |
Nice work Vic on the fitting, I'm always amazed at how you improvise to have the perfect parts. I feel like I'm the candy striper if your the mid wife lol. I truely do appreciate all the hard work you put into my engine. From design, to assembly, to paint, to crate and delivery.
Thank you Vic!
Scott Last edited by sduckworth13; 09-17-2014 at 10:13 PM. |
#1275 | |
![]() Join Date: Sep 2010
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
