Old 08-30-2014, 09:33 PM   #1
Andy4639
Old member
Andy4639's Avatar
Cool Interesting site
I found this site while surfing tonight. Very nice stuff with some good info on what to look for and what mods to do to mine I think. I like the 6.0 SS cam mod.
This may be of help to some of you.
Some ECM's tach signal is not strong enough for some aftermarket tach's. This method can be used to “boost” the signal from the ECM. All you do is hook one end of a 680 ohm resistor (SUPPLIED BELOW) to the tach wire, and other end of the resistor to a keyed 12V+. This may not be needed with all tachs and all ECM’s. The pre 2002 ECM’s and tach combinations seem to be hit-and-miss. So far, all 2003+ have had to have it.
http://bdturnkeyengines.com/engine-g...b090cd25be8324
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-31-2014, 09:23 AM   #2
aknovaman
Re: Interesting site
FYI
It's not a matter of the signal is not strong enough.
The older blue red PCM tach output is a pulse that goes from zero to 8 volts. The green blue PCM actually provides a ground when the coils fire. A tach needs a voltage transition close to 5 to 7 volts to read. So on the newer pcm's when the coils are not firing the resistor pulls the voltage up to 12 volts then when firing the PCM provides a ground to make the voltage transition across the 5-7 threshold making the tach read rpm.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 08-31-2014, 10:17 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Its similar info to what we've used here for a while. The OG thread goes back a ways:
"Conventional Tach on LS2" by TR65.
http://67-72chevytrucks.com/vboard/s...d.php?t=445975
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-31-2014, 06:54 PM   #4
Andy4639
Old member
Andy4639's Avatar
Question Re: Interesting site
Guy's not hammering the info here just thought I would add to it.
