![]() Join Date: Mar 2012
opinoins on coil spring shocks/self leveling
MONROE Part # LE40527 Limited Edition; Leveler; Sold in Pairs
REAR w/Rear Coil Spring;For Towing and Hauling [Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty] found these on rock auto, do they ride good on our trucks??
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Re: opinoins on coil spring shocks/self leveling
You do not want to put to much weight on the shock hangers as they were not designed for it. I would use sleeve bags as a helper hooked too schrader vales to fill up when necessary.
Plus I think they would just make your ride rougher all the time. |
