Old 08-31-2014, 09:14 PM   #1
davepl
davepl's Avatar
Power steering pump
For the '70 big block, which uses a remote reservoir, LMC wants about $200 for the pump.
Rockauto lists pumps for:
"1970 GMC C25/C2500 PICKUP 6.6L 402cid V8 : Steering : Power Steering Pump"
Except they're $28 bucks, so can that be right?
They show Cardone #20140 or ACDELCO 36P0167
The LARES 2129 is only $27, but has a $75 core
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-31-2014, 10:14 PM   #2
airdale94
airdale94's Avatar
Re: Power steering pump
I would say if RockAuto lists it, then go for it. Unless there's something very unique about it. Honestly LMC would be the last place I would look for something like a ps pump. I've bought alot of parts from RA always on with descript. and what they say.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 08-31-2014, 10:40 PM   #3
franken
I'm not sure why people buy auto parts available (from any auto parts store) locally, or from rockauto from ripoff places like LMC...
If you are replacing a pump you already have, you can get a bare pump, pop the can off and get out cheaper. The pumps are mostly the same, while the enclosures and peripheral bits varied. I had to do this with a mystery pump that I couldn't match.
If you have a press (for the main bushing), rebuild kits are available.
Old 09-01-2014, 12:44 AM   #4
leddzepp
Moderator
leddzepp's Avatar
At $28 I guarantee you it ain't the right one. The big block remote reservoir pump is not available at any of the box stores to my knowledge. $150-200 is what I have found for the correct one that has been rebuilt. 66-68 big block cars use the same pump, but the return nipple location on the back is different IIRC. When you locate one and swap your pulley over, be sure to use the correct tool to remove it. Often times guys use a three jaw puller or beat it off with a hammer, resulting in pulley wobble and belts being thrown after you reinstall it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-01-2014, 07:51 AM   #5
midniteblues
midniteblues's Avatar
although i've never had a problem with r.a they seem too be the best bet out there.
unlike the auto stores where i've had too return return and return parts and even over the phone they cant get it right.
r.a theres no verbal commincation(i've never have had too) and they allways seem to get it right.
now i would be very leary of a cheap ps pump but perhaps they are cheap cause they dont sell alot of'em.
i would say if you cant locate a good original then a rebuild of the one you have (come on YOU can do this) yes led zep said it dont use a 3 jaw puller.
then a r.a pump as a last chance.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 09-01-2014, 01:15 PM   #6
FirstOwner69
FirstOwner69's Avatar
I've had nothing but good luck with Rock Auto. That said, I know nothing about the differences between the big block pumps and small block pumps other than the remote reservoir is used for big blocks. The Rock Auto catalog shows the same "without reservoir" pumps for big and small blocks. However, they only show pumps both with AND without reservoirs for small blocks. This indicates to me they are aware of a difference. I assume that there is some sort of housing that the big block pump is contained within. If so, is it also possible that the same pump is used for both applications, but the small block pumps are placed in a housing with an attached reservoir vs. a different housing for big blocks? Please educate me.
EDIT: I may have just answered my own question. Classic Industries sells pumps only (no housing or reservoir) for both engines. They do indicate different part numbers, but the same price..$49.99).
FirstOwner69 is offline   Reply With Quote
Old 11-08-2014, 10:42 AM   #7
engineer_gregh
engineer_gregh's Avatar
Hi Dave, did you order the pump from Rock Auto? Mine is bad on my 71 big block so I need one as well. Thanks.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 11-08-2014, 10:55 AM   #8
Scottcoda
Scottcoda's Avatar
DON'T FORGET YOUR DISCOUNT CODE!!!!
Rock Auto code 5% expires on November 23, 2014.
2551297923732890
How to Use Your Discount Code
Enter the code above in the "How Did You Hear About Us?" space on the checkout page (above your payment information). Do not enter any other text in that space or the discount will not apply. Click the "Apply" button and your discount will be subtracted from your parts order total.
Please note: Discount only valid for orders placed online. Code must be entered before order is submitted.
The discount takes 5% off our already-low prices. There's no limit on order size or the number of orders. Use the code for your next order, and share the code with anyone you know who works on cars or trucks.
68 GMC 2500 stepside LWB 250CI
Scottcoda is offline   Reply With Quote
Old 11-08-2014, 06:29 PM   #9
mechanicalman
I'm 99% sure that does not include the right housing.
Of course, the shaft has to fit your pulley. Some had a key-way, most are just pressed on.
Just about any pump will work if you transfer your old housing, O-rings are new on the new pump.
If the high press hose does not fit, simply transfer the old flow valve out of your old pump using the new o-ring on the flow valve that don't fit.
Good time to paint that rare housing, or take it to the chrome shop.
mechanicalman is offline   Reply With Quote
