Old 09-01-2014, 02:56 AM   #1
Chevy1966
327 fan setup
Working on my '66 custom camper with original 327 - does anyone know what kind cooling fan came on this engine from the factory? Did they come with a fan clutch? I have one of those fans with the flex blades and I am sure this was not the original configuration. I'm trying to take the setup back to the way it came from the factory. thanks - Rob
66 Custom Camper 327 AC PS PB
66 C20 292
76 C25 Sierra Classic
76 C25 Sierra Grande
76 Camper Special
77 Sierra Grande
02 Suburban - the DD
Chevy1966 is offline   Reply With Quote
Old 09-01-2014, 03:09 AM   #2
B_Bob
Re: 327 fan setup
Here's a pic of my '65 with a 283. It's a 4 blade. Should be the same as a 327.
B_Bob is offline   Reply With Quote
Old 09-01-2014, 03:15 AM   #3
Chevy1966
Re: 327 fan setup
Thank BBob... so do you run with a fan shroud or just as shown in the pic?
66 C20 292
76 Camper Special
77 Sierra Grande
Old 09-01-2014, 03:37 AM   #4
B_Bob
Re: 327 fan setup
I switched to a 4 row radiator and 7 blade fan with clutch. I also picked up an original shroud and mounting brackets that I have yet to install. The 7 blade does a good job though, even in the Phoenix heat. If you can't find one locally, I've still got the 4 blade. Should be cheap and easy to find at a scrap yard though.
Old 09-01-2014, 03:47 AM   #5
Chevy1966
Re: 327 fan setup
Thanks for the very helpful info. I will look for the fan and shroud at the local scrap yard. --Rob
66 C20 292
76 Camper Special
77 Sierra Grande
Old 09-01-2014, 09:21 AM   #6
yelmer
Re: 327 fan setup
they would run a 4 blade and 5 blade . you could also get a clutch fan setup with 5 blade . they all used the shroud .
yelmer is offline   Reply With Quote
Old 09-01-2014, 10:37 AM   #7
AcampoDave
AcampoDave's Avatar
Re: 327 fan setup
BBob, which clutch fan did you buy if you don't mind. Did it have a themostat? Where'd you get it? Also does a 4 row fit in the stock brackets? Thanks
AcampoDave is offline   Reply With Quote
Old 09-01-2014, 11:46 AM   #8
yelmer
Re: 327 fan setup
4 row has different brackets up and down and the pads are different from the others. the tanks on the 4 row are 3.5" the others are 3.0"
Old 09-01-2014, 11:54 AM   #9
63burban
Chevy addict
Re: 327 fan setup
My 1965 C30 camper/motorhome has a 5 blade fan with clutch and schroud
63burban is offline   Reply With Quote
Old 09-01-2014, 02:24 PM   #10
B_Bob
Re: 327 fan setup
I have no idea what clutch it is, I bought it used. It's actually a Champion 3 row (CC284). Had to look it up, it's been a while. I like the look of the old radiators, but the price was right, so aluminum it is! It fit perfectly in the saddles, but I had to get a new top hose because the old connection was in the center, and the new was on drivers side. For anyone with the same challenge, I got the hose from O'Reilly's part number 20607.
Old 09-01-2014, 02:43 PM   #11
grs
Re: 327 fan setup
Where did you buy the radiator? Is it a desert cooler. I would like a 7 blade fan without the clutch. Where can I get one?
grs is offline   Reply With Quote
Old 09-01-2014, 02:53 PM   #12
B_Bob
Re: 327 fan setup
I got the radiator on ebay. You can get a 7 blade fan at any parts store. I do like that the clutch gets the fan a little closer to the radiator. Here's a little eye candy for ya.
Old 09-01-2014, 10:40 PM   #13
sodly
sodly's Avatar
Re: 327 fan setup
I'll defer to Yelmer on this but I think the determining factor on the fan configuration was the transmission on your Custom Camper. The TH400 auto got the bigger, 4 row radiator. Not sure if the stick did or not. Mine has the TH400, as does Yelmer's, with a shroud. My fan is 6 bladed.
Check out our little Custom Camper club here: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 09-02-2014, 02:24 AM   #14
Captainfab
60-66 Nut
Re: 327 fan setup
The OP's truck also has AC which I think would require a better fan than typical. I'm not sure if it would have been a clutch fan, but highly possible.
Old 09-02-2014, 03:53 AM   #15
Chevy1966
Re: 327 fan setup
So is the 7-blade fan with a thermal clutch the ultimate solution for the best cooling (with A/C)? Although I understand how it works mechanically, guess I am not totally sure how the fan clutch affects the cooling. When the clutch heats up, the fan turns slower, right? So is the idea that too much airflow is a bad thing? I really want to thank everyone to some great replies to my post. PS: BBob, that's a good looking engine - is that in your ride now?
66 C20 292
76 Camper Special
77 Sierra Grande
Old 09-02-2014, 10:21 PM   #16
sodly
sodly's Avatar
Re: 327 fan setup
I didn't know clutch fans were available on 66 pickups. I've been wrong before but I thought they were a later development, no?
WANTED:
Old 09-02-2014, 10:36 PM   #17
Budman56
Budman56's Avatar
Smile Re: 327 fan setup
Here is a very oil untouched 65 c20 327 that had a 5 blade fan with a clutch. Here are before and after photos, havent put the fan back on yet.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 09-02-2014, 11:35 PM   #18
60-66
60-66's Avatar
Re: 327 fan setup
The Chevrolet parts book lists the clutch for 1965 1966 3883158 with Air Cond and HD Radiator. Was able to find clutch fans for trucks back to 1961 although rarely seen on trucks.
The standard HD fan was a fixed 5 blade no clutch. This fan is shown in the 64-66 factory Air Conditioning instruction manual. Heres a picture on a factory air 1966 292 .
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 09-02-2014, 11:55 PM   #19
yelmer
Re: 327 fan setup
The oct 67 chevrolet parts book lists 65 -66 series 10-30 c.a.c. H.d. Radiator 327 part 3883159 fan blade 2nd design also the clutch for the blade is part 3883158 serie 10 -30 w a.c. H.d rad 327 2nd design
Old 09-02-2014, 11:56 PM   #20
pimpston65
pimpston65's Avatar
Re: 327 fan setup
wanna let any of those L6 parts go????
pimpston65 is offline   Reply With Quote
Old 09-03-2014, 12:03 AM   #21
yelmer
Re: 327 fan setup
The clutch
Old 09-03-2014, 12:06 AM   #22
60-66
60-66's Avatar
Re: 327 fan setup
Sorry Winston but this is one of the trucks I need that shroud for. 1966 short fleetside 292 Ac truck
Old 09-03-2014, 12:07 AM   #23
60-66
60-66's Avatar
Re: 327 fan setup
Originally Posted by yelmer View Post
The clutch
What's the blade look like Yelmer ?
Old 09-03-2014, 12:17 AM   #24
yelmer
Re: 327 fan setup
I will need to take a picture will post later
Old 09-03-2014, 12:19 AM   #25
pimpston65
pimpston65's Avatar
Re: 327 fan setup
i got this one from a guy claiming correct for L6 with ac
