Old 09-01-2014, 08:37 AM   #1
midniteblues
midniteblues's Avatar
fire wall pad retainers
anybody have any tips on getting these buggers too pop in the holes I've ruined one allready tryin too bang it in.
I dont wanna drill the holes bigger.
my search pretty much came up with "buy gmc pauls" brand.
i would really like too use the ones i have.
yes homer is makeing a statement
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 09-01-2014, 10:07 AM   #2
71 super
71 super's Avatar
Re: fire wall pad retainers
Add some type of lubricant to it, and get a cheap screwdriver , cut the driver down to use as a " pusher" and stretch good before you start. You may also warm the pin up to soften it to ease installation.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 09-01-2014, 10:38 AM   #3
70shortfleet
70shortfleet's Avatar
Those hard plastic retainer are junk! have never had any luck getting them into the hole. Best bet is to find some soft rubber ones.
70shortfleet is offline   Reply With Quote
Old 09-01-2014, 11:58 AM   #4
Lee H
Lee H's Avatar
I ruined enough I would have needed two kits to get enough to do the job with the generic plastic fasteners. And they look bad on the firewall side. I ended up cutting them out getting the correct rubber ones.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-01-2014, 01:27 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
From the factory, I'm sure they were made to be installed once.
They are basically a one way push through, and if you have to remove them, you have to replace them. Just the way it is.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-02-2014, 06:04 PM   #6
midniteblues
thanks I was makeing one rite around the time you were replying I tryed it a few differnt ways and all i could do is bend the shaft
then.....
I was so po'ed at these lil' peices of plastic cheesy looking peices of junk.
i got the bike out and beat on the poor lil' sporty for a while.
paul will get my order.
thanks guys
Old 09-14-2014, 08:38 AM   #7
midniteblues
after a lil' while i had a severe brain fart. holey cow! i have a parts truck out back
yep pulled all the retainers then cleaned them up.
back in the garage i got too looking for my firewall grommets an guess what i found in my "bagged and labeled parts" i dont remember pulling these out i thought i just snipped them and chuck'm.
i held off ordering these glad i did i dont need 3 sets
ahhh they work so much better
sometimes i wander about myself
Old 09-14-2014, 08:48 AM   #8
midniteblues
i forgot the pick...interior somewhat assembled.
i kept the fatmat hidden from plain view.
also put 2 layers of jute under the rubber mat.
my new gas pedal broke the first time i installed it....junk
