09-01-2014, 03:08 PM | #326 |
Re: Project 30 years sitting
Alright, back to sheetmetal progress. Core support painted, and then repo fenderwell painted.
09-06-2014, 07:38 PM | #327 |
Core support on, trans cooler on, electric fan on, lower hose on. Then also replaced the cup on my replacement fender, welds filled, sanded, and rattle can primer for protection for tonight.
Also took 8 parts to the powder coater this week. |
09-10-2014, 09:09 PM | #328 |
So motor started for the first time tonight since cam swap. But it fired off on second try. Pass fender is in self ectching primer after sanding off a coat of filler primer. So it will be layed outta the way and hopefully early next week I can take the door off, replace box, skin, and convert it to metal panels rather then plastic.
09-11-2014, 04:26 AM | #329 |
Nice work Dale.....risen from the ashs
10-04-2014, 08:22 PM | #330 |
Alright, back in business. Was out of town for a week, trying to sell parts, and bought an utv for work and had to do a few things to it for our use. So, working on fixing door rust. New box, patch from an old door set, and will be re-skinning it. Swapping it to metal door panels as well.
10-07-2014, 01:43 AM | #331 |
GEARHEAD
Wow, never seen door rust in that upper corner before. Looks good though.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
10-07-2014, 07:47 AM | #332 |
When it was parked for all the years, the door was left hanging open. That also caused one of the hinges to to jam up and be replaced.
Got some bondo smeared on it last night. |
10-08-2014, 09:43 PM | #333 |
operation door still going on........
picture of my satellite antenna for a user. |
10-09-2014, 10:25 AM | #334 |
10-09-2014, 10:46 AM | #335 |
nice build and its come a long way from sitting in the weed(s)
at when you bought the truck, was the paperwork in other or did they have a few hiccup(s) along the way .... ??? and can not wait to see the rest of the update(s) being done to it =0)
dont want to hear excuses, i want to hear solution(s) |
10-10-2014, 10:03 PM | #336 |
Lokin, Thanks. I had a few hickups getting the paper work. But I do have title and its clean with no special markings. Looks the same as all my other ones.
Got the skin on tonight. First attempt. I think it looks good Obviously learned a few things I can apply on the next one. Biggest disappointment is that the tool is so large, I can not get it at the angle I need for the bottom flange. |
10-11-2014, 10:03 PM | #337 |
Made it to the last show n shine of the year. Taking a rest from it tomm to do a few other things.
10-18-2014, 08:54 PM | #338 |
got the front done in epoxy primer, but screwed up the right one by flipping it over before it was dry and painted the inside. So have to redo it tomm.
10-19-2014, 06:41 PM | #339 |
fender redone, bolts in all holes, hood on..... which was more of a task than it sounds. Found out the hood was twisted quite bad, and the hinge I got off my parts truck was worse than the one that was in the wreck.
10-19-2014, 11:36 PM | #340 |
I'm trying....
Yes...I'm curious about your reception as well. I have been thinking about this a lot. There are no good locations, and most manufacturers want it on the roof or on a deck lid if it's a convertible. I just want it invisible and I do not want to drill any holes (pipe dream). That would be a great location if it works.
10-20-2014, 07:48 AM | #341 | |
10-20-2014, 08:23 AM | #342 |
I'm trying....
10-20-2014, 10:14 AM | #343 |
I figured you didnt see that post. Thats why I mentioned it started elsewhere.
10-22-2014, 09:04 PM | #344 |
Almost street legal again.
10-22-2014, 09:18 PM | #345 |
Where did you get the clear marker lenses?
10-22-2014, 09:27 PM | #346 |
LMC #36-4413 (qty2). You have to drill the rivets out of a stock set of housings. Then use the "rivets" they provide, and expand them with a punch. Not a rivet gun. The right housing is the one that was in the wreck.
10-22-2014, 09:28 PM | #347 |
oh wait, side marker lights. Crap....I wanna say gmc pauls maybe?
10-22-2014, 09:33 PM | #348 |
Cool, I was looking for such a thing. Quality seems nice?
10-22-2014, 09:39 PM | #349 |
ehh, the chrome rings started falling off after about a year. I ended up pulling all of them off, asking on hear and getting some epoxy glue and re-gluing them.
10-22-2014, 09:42 PM | #350 |
ok, this is the site I got them from. http://www.manestruckparts.com/store...Category_ID=14
