Old 09-01-2014, 09:03 PM   #1
ah_5500
Getting that factory AC going again.
I decided it was time to get the original ac on my truck going. Everything is there and there are no leaks. So we pulled a vacuum and charged a couple cans of 134. I thought and partially assumed it had been converted from r12.
How do I know if it's been converted? How do I convert it if it hasn't?
The air got cold but pump started sounding and acting like it was about to lock up like it needed oil. School me on oiling please.
Lastly, the pump didn't cycle. It ran without shutting off.
Thanks in advance!
ah_5500 is offline   Reply With Quote
Old 09-02-2014, 01:06 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Getting that factory AC going again.
Here's some information to help you out.
http://www.google.com/custom?domains...D%3A1%3B&hl=en
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-02-2014, 04:03 PM   #3
joey8383
joey8383's Avatar
Most people put the 134a quick connects on the lines when converted, although they are not 100% necessary. On the oil, when converting you should unbolt the compressor, dump all the old oil in to a measuring cup, then refill with PAG oil which is 134a compatible. If you were low on oil then just look up the oil capacity for the compressor. Dump the oil straight in the compressor through the suction line hole.
The compressor usually cycles on the low pressure switch when running. If you had the fan on high and the cab was hot, you were introducing a lot of heat in to the refrigerant in the evaporator and that causes the suction pressure to run higher. Most low pressure switches open around 15-20psig. You may have to drop the fan speed to see the suction pressure drop enough to open the low pressure switch.
The only method for charging a vehicle correctly is to weigh it in. if it holds 2 lbs, put in a couple 16 oz cans or similar after you pull a good deep vacuum.
In a pinch, I have topped off many cars by rules of thumb. Charge it up to about 35-45psig on the suction side (assuming a 75-80 degree cab and fan on high speed) and it will be close. That is the equivalent of about a 40 degree evaporator saturation temp and will get you close.
In my opinion, a lot of R12 condensers are too small for 134a. Look at a newer truck's condenser than compare it to our old R12 condensers. This will cause the refrigerant to not 100% condense and also cause high head pressure. If it doesn't condense completely you won't get 100% liquid to the metering device and you end up with a starved evaporator. Do you have a set of gauges to hook up to the truck where you can see suction and head pressure?
joey8383 is offline   Reply With Quote
Old 09-02-2014, 04:19 PM   #4
WhiteWhale
WhiteWhale's Avatar
subscribed
WhiteWhale is offline   Reply With Quote
Old 09-04-2014, 10:41 PM   #5
ah_5500
Thanks. Yes I have gauges. Just to be clear, which is high side and which is low side. I believe I had it correct but it doesn't hurt to be sure! I have found some r12 so I plan to pull vacuum and recharge with that.
I want to change the oil before recharging. What is your suggestion on oil to put back in? Amount? Thanks again
