Old 09-01-2014, 09:05 PM   #1
86c20
86c20's Avatar
air injection manifold plugs
ok so my 350 has the air injection set up and broke one of the tubes that goes to the manifold so i have a leak got the nut out of both sides tonight was just wondering if anyone knew the thread or where to get plugs so i can pass a cop with out being to loud lol, thanks mike
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 09-01-2014, 09:15 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: air injection manifold plugs
I've had luck with Cummins engine oil drain plugs working.
Old 09-01-2014, 09:39 PM   #3
Just call me Sean
Just call me Sean's Avatar
I only did it on my Ford, but it should be the same. The threads should be NPT (national pipe thread) so take the piece you removed to Lowes or Home Depot to match it up. Some auto parts stores might have NPT plugs too.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 09-02-2014, 02:34 AM   #4
frank69
I use 1/4 in. npt plugs.
frank69 is offline   Reply With Quote
Old 09-02-2014, 12:50 PM   #5
86c20
86c20's Avatar
it dont seem to be npt seem metric??? its a crate motor form mexico if that helps any and this is 3/4 od like a half inch pipe
Old 09-02-2014, 02:56 PM   #6
oily
I measured mine a few years ago. They were 19mm with a very fine thread and straight [not tapered]. Also the threaded hole wasnt that deep, so tapping them to pipe thread would be iffy. I would try a drain plug [Corts60] first. You need a friendly parts guy to try out the many sizes.
P.S. At the bottom of the threaded hole, the size reduces down to about 5/16 or so. You could try tapping that to a pipe plug, but I dont think there is much material to work with.
oily is offline   Reply With Quote
Old 09-02-2014, 08:00 PM   #7
Corts60
Just here to tinker
Corts60's Avatar
19mm and yes the threads are straight. No idea what pitch i.e.: 1.5, 1.25, etc. This is what a cummins drain plug is.
Old 03-27-2015, 07:04 PM   #8
69m22zl1
Did you ever find a plug that worked in the manifolds? If so where did if find them? part # ? or who has them for sale?
69m22zl1 is offline   Reply With Quote
Old 03-27-2015, 08:14 PM   #9
86c20
86c20's Avatar
well see its like this, i gave the old nut that goes around the tubing to my gf and she found a plumbing bushing that fits. it is the most odd ball thing ever. it is comp by pipe adt and it went right in. think it is 3/4 can take a pic if needed but its not pretty. but i dont care it works
Old 03-27-2015, 10:16 PM   #10
69m22zl1
Thanks for the quick reply, I'll check that out! Thank you!
Old 03-27-2015, 10:36 PM   #11
Titomars
Titomars's Avatar
Most GM AIR injection tubes are fitted to the manifolds with flare nuts which are straight threads not NPT. I always use Allen head set screws. The size I have used is 1/2 X 20 the taper of the set screw tip is close enough to the 45deg flare which lets the set screw seal at the flare not the threads. I also use anti-seize on the threads for removal at a later time.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 03-27-2015, 11:44 PM   #12
Pampas56
When I had to replace the air injection tubes on my 350, we drilled the old flare nuts out and cleaned the threads up with a pipe tap. We discovered that they were a standard 1/4 inch NPS thread and dug up a straight plug tap to do the job.
A 1/2 by 20 plug would work worse than a 1/2 by 13 plug as the normal pitch of a 1/4. inch pipe thread is 14 TPI
1989 Silverado K2500ECLB- 307K miles with 90 K TBI 350-Not a show truck, a work tool that I can drive!
1992 K1500 ECSB- 190K miles- I guess I'm just a truck guy now!
Pampas56 is offline   Reply With Quote
Old 03-28-2015, 12:08 AM   #13
Titomars
Titomars's Avatar
Ahhh but 5/16 inverted flare nut threads are 1/2 X 20. Anyway that's what I do on my pre 81 vehicles. Now I can't really speak for newer engines. They might be metric for all I know.
Old 03-28-2015, 07:31 AM   #14
86c20
86c20's Avatar
here is one thing i want to ask on this. are you guys using the 1/2 on the single line air or is it on the ones with 3 or 4 lines to the manifold?? mine is single
Old 03-28-2015, 11:29 AM   #15
Titomars
Titomars's Avatar
Sorry I was talking about the standard four tube AIR rail to exhaust manifold.
Old 03-28-2015, 01:02 PM   #16
69m22zl1
I cut the air injection tubes and used a 22 mm to remove the them.
It looks like fine thread . An earlier post, Someone posted they used 19mm oil drain plug from Cummins diesel . Does anyone know year make model plug is from? Or if any of you can point out the plug I need would be very helpful . Thank you!
Old 03-28-2015, 01:10 PM   #17
69m22zl1
What year , make , model did you get the Cummins engine oil drain plug from?
Old 07-13-2021, 12:40 PM   #18
Hart_Rod
Hart_Rod's Avatar
Bump. Anyone have an answer to this?
Hart_Rod is offline   Reply With Quote
Old 07-14-2021, 07:39 PM   #19
Corts60
Just here to tinker
Corts60's Avatar
Been a long time since I worked on this stuff, but try buying one of these and see if it works.
M22x1.5
https://www.napaonline.com/en/p/NDP7...&gclsrc=aw.ds&
Old 07-15-2021, 09:03 AM   #20
Hart_Rod
Hart_Rod's Avatar
M22x1.5
Thanks! I grabbed 2 at the parts store and the fit perfect, . For future questions on this matter, the part number is Dorman 652886.
