Drip rail question
I was looking at CopperHead a couple days ago and got to thinking about the shaved drip rails. What do you guys think about it.
Bowtie Club of the Carolinas |
Robert Olson Transport
![]() Join Date: Oct 2002
i like the driprails it looks classic and thats what these trucks are classics
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
I guess that it comes down to the age old question -- Custom or original
In my opinion the drip rails are a functional part of the design of our trucks. Personally I wouldn't "shave" 'em. Now, if a fella was inclined to build a shaved, slammed and chopped truck for occasional use, by all means do so. We've all seen some really well executed mods, and some pretty sloppy ones as well. If you decide to go ahead with it, make sure you weld it up solid, as the drip rail is what holds the top of the cab together. Good luck!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
Car Knocker
I plan on doing mine when I chop the top. IMO anybody can have a stock truck.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
i think they kinda look neat, and wouldnt water get all over you when you open/close the door and its raining outside? (with no drip rails). just gotta watch em for rust thru.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
CCRider
The 67-72 Chevy truck was the first modern truck. Every truck made since then copied or stole some of its design....and Chevy went down hill somewhat after that...mostly because the government was getting in there business and they were spending all their money trying to meet the new gov specs on pollution and crash worthiness. I love custom stuff but in my opinion 99% of the "custom" 67-72's I see just don't look as good as a bone stock Cheyenne. From 73 up...break out the mig welder and have a party
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS Last edited by tom hand; 01-17-2004 at 01:28 AM. |
Formerly yellow72custom
GM tried removing the driprails on the early '73-'87 trucks....the cabs had a bad problem of getting water in them.
Slightly later model trucks (not sure which year) have bolted-on driprials. Think it started around '75 or so, but i don't know those trucks that great. I wouldn't shave them myself, but i much say that it does make a very clean and handsome package....would look pretty good with 1-pc windows, and all trim removed (please KEEP the doorhandles though!).
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
I know that this is going to sound weird but here is what I am going to do -- Shave the drip rail, put Bear Claw door latches (for a custom look) -- I have already moved the gas tank under the bed, and I have shaved the firewall and hidden all the wires from the firewire. I would like for it to look stock from the outside with a few mild customs. Any other ideas are greatly appreciated.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Shave em!!!! But I would reallly think about it before you do it one you cut em off that's it no going back!!!!!
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
drag it like you stole it
i got water in my lap the first time i got in my truck after a hard rain. but it was worth it. heh
negative camber //LA\\ |
A-Adam A-Adam
I like the looks of Shaved. Not sure how much work it is!
70 3/4 ton GMC Camper Special |
#13 | |
Vortec in the works
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
lotik, do you have a pic of your cab. I would like to see one shaved.
#15 |
PROJECT 7DEUCE
Here is a pic of lotik's bad a$$ truck..
#16 |
hey lotik what do you mean you got water in your lap... getting in and out of the truck the water runs down the sides into your lap?
70 longbed 496/th400/Ford 9" |
#17 |
That is beautiful truck lotik. I don't know that I am going that custom but I just want a few things that are custom
#18 |
Car Knocker
I have not chop one YET. The chop I plan on doing is a 2" rake and 1 1/2" chop. Not to much, I'm 6'3", just enough to be different. There is an article in Classic Trucks/November 1999, that does this same chop. I brings the back window level with the door glass and removes the drip rail. My truck will some day look almost like Lokit's. If I ever quit getting laid off, 3 times since November 2002. Here is a pic of what I'm talking about.
#19 |
I have looked at several choped tops and that is the one that I like best. Although I don't think that I am ready for that yet.
Oh yea -- I finally got an avatar
