Old 09-03-2014, 01:54 PM   #1
chevytrucks31225
Front end swap
I know this has probably been discussed on here and if someone could point me to the appropriate thread I would appreciate it. I'm entertaining the thought of putting 73-74 sheet metal on the front of my 81 and was wonder what problems I will encounter or if it is even possible. Thanks
chevytrucks31225 is offline   Reply With Quote
Old 09-03-2014, 03:33 PM   #2
mturner0111
Re: Front end swap
Should be a direct bolt on with some minor tweaking the harder swap is going 73-79 to 81 an up the cabs have different holes for the hood to bolt up that you've got to workout, Hope that helps you!
mturner0111 is offline   Reply With Quote
Old 09-03-2014, 03:36 PM   #3
chevytrucks31225
Re: Front end swap
Thanks, makes me more confident to dive into this project
Old 09-03-2014, 03:51 PM   #4
xrcr
Re: Front end swap
You'll have to switch out the wipers to the older year
xrcr is offline   Reply With Quote
Old 09-03-2014, 03:53 PM   #5
mturner0111
Re: Front end swap
If you need pics just let me know.
Old 09-03-2014, 04:07 PM   #6
chevytrucks31225
Re: Front end swap
Pics would be very helpful. What is different about the doors, when you look up replacement doors they go from 73-77 and then 78-87? Does that have to do with brackets that mount the interior components?
Old 09-04-2014, 12:12 AM   #7
mrolds88
Re: Front end swap
Doors are 73-76 and 77 up. It has to do with the interior panel mounting.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 09-15-2014, 05:53 PM   #8
Sodak
Active Member
Re: Front end swap
I would also like to do a swap of the older sheet metal to an 81 cab/frame.. anyone know what all is involved ?can this be done without a lot of cutting?
Sodak is offline   Reply With Quote
