Old 09-04-2014, 06:58 PM   #1
81GMCSierra1500
81GMCSierra1500's Avatar
Air Conditioning Compressor clutch not engaging...
So, I just went and bought a recharge/retrofit kit for my A/C, and it now has a full charge and no leaks, but I have discovered that my A/C compressor clutch isn't engaging when the lever is turned to "max" or any other settings, what are the potential causes? It was working maybe 3 months ago, but I am suspicious about a possible blown fuse? There are no fuse block diagrams that look like mine, and half the lettering on it is either work off or unreadable/not understandable... Hopefully I can find an answer... next after this, heater!
1981 Sierra Classic 1500, 305 4BBL, Ltd. Slip Rear End
81GMCSierra1500 is offline   Reply With Quote
Old 09-04-2014, 07:02 PM   #2
81GMCSierra1500
Re: Air Conditioning Compressor clutch not engaging...
I do remember lubricating it at one point because it was making a horrendous grinding noise, but it still worked after that point, and only just today did I notice it wasn't rotating...
Old 09-04-2014, 07:39 PM   #3
Just call me Sean
Just call me Sean's Avatar
How did you manage to get a full charge in there if the compressor wasn't engaging?
Grinding isn't good. First comes grinding, then the compressor locks up.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 09-04-2014, 07:43 PM   #4
81GMCSierra1500
It's not the "locking up," it doesn't lock up... the clutch isn't engaging with the compressor pulley. And on the topic of the pressure, it pressurized according to the gauge, I am not sure exactly how much is or isn't in there, but I just found a completely melted plug sitting loosely behind the compressor body, with a green and black-ish wire in it. Is that the electrical component required to engage/disengage the clutch?
Old 09-04-2014, 07:45 PM   #5
Just call me Sean
Yes, one green wire one black wire.
Old 09-04-2014, 07:46 PM   #6
81GMCSierra1500
So that's the only issue... I will get that sorted, and everything should work! Thanks for the tips, though!
