09-04-2014, 08:53 PM | #1 |
traction problems
i am running a 275/60/15 m/t drag radial and cant consistently get it to hook, just wondering what kind of tire pressures and how long of a burnout your doing. my set up is a 65 fleetside stock suspension except for a 4 inch lowering spring, 4.10 gears, turbo 350 leaving off the foot brake at several different rpms, tci 3500 stall, basically everything is stock except fuel tank is in the rear, healthy 406 sbc and a 150 shot. any help would be appreciated. my 60 foot ranges from 1.510 to who knows.
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
09-04-2014, 09:23 PM | #2 |
Re: traction problems
Flip,
The lowering spring is not helping the situation as it is too short/stiff. Get the truck weighed both front and rear axle weights and I can try and point you in the right direction for a better front spring. What size wheel is on the rear? What do you have for shocks? Any idea on your pinion angle? I am assuming no rear anti-roll bar.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
09-05-2014, 07:58 AM | #3 |
Also learn to read the starting line and look at the track out to about 60 foot. Watch the way the track prep is done and how it is maintained during the day. Over time you will learn to read the conditions and make changes to the launch and the timing of the nitrous based on the track. This will also help you when you test to tell if the changes you make help or not. Also pay attention to where you line up on the starting line and what the track looks like in that grove. Some time being off a foot can make the difference between good or bad hook.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-05-2014, 11:32 AM | #4 |
mini truck racer
Radials are kind of a different monster . Moving over out of the "groove" is a start . The "groove" i have found is not always the best place to even with a slick . My track is very narrow and moving to one side or the other typically yeilds ma a good launch . Next round all i here are mutters of the track is junk . A radial likes to be pressured to the point of spinning and that pressure steadily applied . If the extension is set to fast on the rears and youapply and unload the tire i have found they dont work . I have only had about 30% success with radials .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
09-05-2014, 12:01 PM | #5 |
1.51 doesn't sound too bad to me (depending on ET).
I spent all weekend running on the 10.50 index and my 60's were in the 1.51 to 1.54 range (naturally aspirated) in my big 'ole Chevelle. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-05-2014, 11:44 PM | #6 |
I will be trying to better my 1.43 at the end of the month. I don't see any reason I can't get in to the mid/low 1.3's.
09-07-2014, 05:04 PM | #7 | |||||
just want to say thanks to all that have replied to this thread its greatly appreciated.
09-07-2014, 06:29 PM | #8 | |
09-08-2014, 09:28 AM | #9 |
You get the hang of it. My last car would 60 in 1.03 and run 4.60's in the 1/8 mile in good air. A long way from the 13 second quarter mile passes in the late 70's. Now back to low and slow.
Jimmy
