Old 09-07-2014, 12:36 AM   #1
RPBurris
RPBurris's Avatar
trans to tcase seal??
Ok. I have a newly rebuilt T350 mated to a np203 and just put fluid in it for the first time since the rebuild. I have transmission fluid leaking from the plate between the tcase and transmission. I thought the tail shaft of the trans would have been sealed and did not put silicone between the tcase plate and trans. Should this be doing this or do i have to take it all apart again? Note that the rebuild is 1 or 2 years old and i am finally getting to the point of getting fluid back in it. Nothing like getting to the point of being nearly done and having fresh trans fluid leaking when i havent even fired it yet. I did a search and found lots of info but none specific to my question. Thanks for all the help!
1969 Chevy K20 Longbed
RPBurris is offline   Reply With Quote
Old 09-07-2014, 02:04 AM   #2
tommartin
tommartin's Avatar
Re: trans to tcase seal??
I have a 79 k10 with the same setup, Th350 to np203. It was leaking right where the trans met the adaptor for the t-case.
There is a o-ring there that I had to replace.*On the other side where the adaptor goes to the t-case you can use RTV or a gasket.
Here is a few pics in this thread, might be helpful.
http://67-72chevytrucks.com/vboard/s...d.php?t=607897
tommartin is offline   Reply With Quote
