Old 09-07-2014, 11:31 PM   #1
big_r101
big_r101's Avatar
1 ton frame thickness
What is the frame thickness for a mid 80's k30? I ask because i plan on boxing the frame and i believe somewhere it said it was around 1/4". I just want to order the right thickness of metal so its as close as possible
1998 Ford Ranger FX4, 3.0 V6, 5 speed manual
1999 Ford Explorer, 4.0 V6, 5 speed auto O.D.
2005 Chevy Colorado, 3.5l inline 5, 4 speed auto
2001 Gmc sonoma 4.3l V6, 4 speed auto
soon to have 1981-88 k30
big_r101 is offline   Reply With Quote
Old 09-08-2014, 02:51 AM   #2
Your41Plague12
Your41Plague12's Avatar
Re: 1 ton frame thickness
It is .224" thick, so pretty close to 1/4" steel. That's what I would use.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 09-08-2014, 02:54 AM   #3
big_r101
big_r101's Avatar
Thats what i thought i had planned on using a26 structural plate steel to box it
Old 09-08-2014, 02:56 AM   #4
Your41Plague12
That should do the trick! Any pics of the project?
Steve
Old 09-08-2014, 03:31 PM   #5
big_r101
big_r101's Avatar
No pics yet, havent had time, but i also have a question about mounting a b&w gooseneck hitch with the fully boxed frame, how would i go about this?
Old 09-08-2014, 10:43 PM   #6
1968vetL-71
Junior Member
1968vetL-71's Avatar
Just curious why you need to box a 1 ton frame? Even with a cummins swap that would be extremely rigid and overkill. Some flex is a good thing. There are tons of cummins swaps even in 1/2 ton frames and there are no problems whatsoever. Not critiquing, just curious why to go through all the work.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 09-08-2014, 10:53 PM   #7
big_r101
big_r101's Avatar
I still havent decided if i will box the whole frame or just part (the front most likely due to the frame cracking issue) but i mainly want to cause of heavy hauling.
Old 09-09-2014, 02:39 PM   #8
big_r101
big_r101's Avatar
And the cummins im going to put in is gonna be around 400hp and around 1000 ft-lbs of torque.
Old 09-10-2014, 01:07 AM   #9
Your41Plague12
1000 ft lbs of torque will definitely be enough of a reason to box the frame. I strongly suggest doing it. It might be overkill, but I'd measure twice and cut once when it comes to something as structural as the frame of your truck.
Steve
Old 09-10-2014, 01:31 AM   #10
Car'n'Guitars
Car'n'Guitars's Avatar
Would like to see pics of project when started, I plan on doing the same sometime in the near future.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 09-10-2014, 01:39 AM   #11
big_r101
big_r101's Avatar
I personally dont think its overkill, i mean they did it for the 2011+ silverado hd's for increased payload, plus it gives me an excuse to get a shiny new miller mig welder.
Old 09-11-2014, 01:47 AM   #12
1968vetL-71
Junior Member
well if its a reason for a new shop addition... then do it! Im all for fabrication and building stuff, i've just seen several cummins projects on other forums that did the same thing your wanting to do and the end result was not what they were hoping for. These old 1 tons can take some serious abuse and have been ran through the ringer on a daily basis for over 40 yrs.. remember when drivetrains and mounts get rigid and stiff... its vibrations and carnage. more times than most, there are far more weaker components than the frame. Thats the beauty of this forum tho.. its different strokes for different folks. thats what were all here for is to share, learn and build from experience. can't wait too see a build thread. good luck!!
Old 09-11-2014, 01:55 AM   #13
big_r101
big_r101's Avatar
Hopefully it will turn out well, im gonna try my best to get the most premium components i can buy, try not to make to rigid, i would imagine a more flexible suspension could help with that? Cause i was thinkin 3" wide leafs and air bags.
Old 09-11-2014, 03:22 PM   #14
Car'n'Guitars
Do you already have a truck or are you searching?
Old 09-11-2014, 03:53 PM   #15
big_r101
big_r101's Avatar
Searching, but im trying to get everything planned out beforehand so i get it done as fast as possible.
