Old 09-08-2014, 05:46 AM   #1
WEBBY1
WEBBY1's Avatar
rear end question
Is it worth it/gain anything to swap rear end to a 5 lug. Or have 5 lug axles put in my orignal. I plan on shorting my rear end a few inches for big tires.
WEBBY1 is offline   Reply With Quote
Old 09-08-2014, 07:07 AM   #2
PGSigns
PGSigns's Avatar
Re: rear end question
The 5 lug will get you a better selection of wheels. That will help when looking for wheels in the size and offset you need to get them under your truck.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-08-2014, 07:08 AM   #3
davbowen
davbowen's Avatar
nice 6 lug wheels are hard to find.
davbowen is offline   Reply With Quote
Old 09-08-2014, 08:33 AM   #4
WEBBY1
WEBBY1's Avatar
Im talking about getting 5 lug axles for my 6 lug rear end?
Old 09-08-2014, 11:16 AM   #5
donthekawguy
donthekawguy's Avatar
Now we don't know what you mean. You can get 5 lug axles. The benefit is more wheel choices. I would hold off on narrowing the rear and see if just widening your tubs will be enough for what you want. Unless your going the pro-street route.
66 shorty
donthekawguy is offline   Reply With Quote
Old 09-08-2014, 11:55 AM   #6
DLW
I would just change the axles/drums to 5 lug of proper length for our trucks. Going to a different 5 lug rear will probably result in a wider rear. Since you want to narrow a rear, either way different axles will be required unless you send stockers in to be shortened.
DLW is offline   Reply With Quote
Old 09-08-2014, 12:40 PM   #7
Clyde65
Clyde65's Avatar
If you have a 64 or down, your better off changing the housing( HO junk and 12 bolt with 17 spline). 65 and up you can change the axles in your 12 bolt
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-08-2014, 01:51 PM   #8
66Submarine
66Submarine's Avatar
63's also used the 12 bolt and '63-'64 used a panhard bar mount that was welded onto the axle tube instead of cast into the center. Why would you use another housing? That makes no sense...
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 09-08-2014, 05:34 PM   #9
DLW
He's saying those year 12 bolts came with 17 axle spline instead of the 30 spline 65-66 came with.
Old 09-08-2014, 05:40 PM   #10
66Submarine
Yes, but why would that make you want to buy a later housing?
Old 09-08-2014, 06:23 PM   #11
DLW
Nothing wrong with the housing itself, pretty much the same housing for all years 63-82 I think, and you can just convert it to 30 spline if you want. I believe the backing plates are pressed on too but that can be changed as well.
Old 09-08-2014, 06:34 PM   #12
66Submarine
Pressed on backing plates are '63 AFAIK.
Yes, all you need to do is swap the spider gears to use the fine-spline axles. That's why I don't understand why you'd want to swap housings...
http://67-72chevytrucks.com/vboard/s...d.php?t=519914
Old 09-08-2014, 10:51 PM   #13
WEBBY1
WEBBY1's Avatar
Thanks for the info.. ill see what it's going to cost to run 5 lug axles in my stock rear end.. reason for narrowing is to run a wide tire with very little back spacing. Its not pro street by any means.. going with the rat rod theme.
