#1301 |
Re: 1963 C-10 in NC
And next week the real fun will begin with the new door weatherstripping. Both the door gaskets and all the door belt line kits. Converting to framed glass and all parts found except the division bar for framed glass. I only find the reline kits....so may be the only option.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#1302 |
Re: 1963 C-10 in NC
6-9" of rain yesterday in our parts, so not much to do outside once I got home.....so inside projects for the night. Started with getting the passenger side donar door stripped down under the porch overhang. This is one of those projects where its nice to have the clutch head socket kit. Have to fill the trim holes and do some patch work on the front corner, but other than that its pretty solid. Must be a 62 door as it doesn't have the view hole on the side and its fawn not silver. I think 63 was the 1st year with the view hole.
Will have a set of standard glass and some extra vent wings, window/door regulators after I'm done with the metal frame glass conversion if anybody is needing 60-63 stuff.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 09-09-2014 at 09:46 AM. |
#1303 |
Re: 1963 C-10 in NC
Back cab trim ready for mock up. Still need to polish the back cab strip. I have another that is ready to go, but it has a small dent, so I'll use this back cab trim and use the other on the fleetside.
#1304 |
Re: 1963 C-10 in NC
And last but not least....I started the clean up on the window frames. I'm not sure, but the frames appear to be stainless. I had some painted areas that had worn through and there was no rust at all around the frame on the glass. I'm sanding it down and polished a test area and I think they'll buff nicely. Still haven't gotten to the bottom of the stainless or not mystery....but it's looking like they are.
#1305 |
Re: 1963 C-10 in NC
Hoping to get this window done tonight and strip driver door as well. Too much moisture in the air for any kind of painting. Need to do a polish on the back cab trim also......
#1306 | |
![]() Join Date: Aug 2013
Re: 1963 C-10 in NC
#1307 |
Haha...right on. More work than paint, but easier to maintain and will loom better in my opinion. Im not a chrome guy if I can polish. The instrument cluster bezel is chromed. But its also cast.
Did get the pass side door hose out. Got a good coat of rust inhibitor/sealer sloshed around in rhwre. Just put a good amount in the door and rolled the door to move it around. Rest will weep out the drains. Got the outer door stripped and have some work to do here to. One dent, two dings and a rust repair on the lower front corner. Will do inner side tomorrow night. Nice steel and no mirror holes to fix though
#1308 |
Re: 1963 C-10 in NC
Here you go pimpston65. 1963 door plug by caplugs...#b-238. Pictured next to the clutch delete plug caplug #b-606. And in silver being oem.
#1309 |
Re: 1963 C-10 in NC
nice, i think the clutch delete is from 67 era cuz the original one i have is less oval,but they both will fit just need some finesse' to get it in...
#1310 |
Re: 1963 C-10 in NC
Man....I really hate when the phone flips my pics. Lets try again.....you can see the dent on the lower edge of the door and the lower corner rust repair. The other small dings are on the body line of the forward passenger door. No door check dents on this one and never had any mirrors on it. Ran out of light at 8pm, so back at it after work tonight. Goal is to strip the inner door then start repairs. The scuff pad on the grinder is cleaning it up nicely. Took around 45min - an hour to strip it, but nice to get it all the way down to metal for repaint.
#1311 |
Re: 1963 C-10 in NC
whenever i take a photo to upload, i take the pic how i want it. then i take a screen shot of the same pic with no banner meaning i crop the pic to show just the item and not the phone info stuff and upload the second edited photo, works everytime
#1312 |
Re: 1963 C-10 in NC
edited photo
#1313 |
Re: 1963 C-10 in NC
uploaded photo without banner, take a sceen shoot of this image and upload this one, you'll end up with 2pics and now you can delete the first...
#1314 |
Re: 1963 C-10 in NC
Ive tried that....tried rotating the pics, which sometimes works. I think I'll just stick to the computer uploads. They always come out right.
#1315 |
Re: 1963 C-10 in NC
#1316 |
Re: 1963 C-10 in NC
Sometimes they are both too much for me. The more advanced they get....the harder they are to use.
#1317 | |
![]() Join Date: Apr 2013
Re: 1963 C-10 in NC
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
#1318 |
Re: 1963 C-10 in NC
Looking good!!
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
#1319 |
Re: 1963 C-10 in NC
Rockin' right along...
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#1320 |
Re: 1963 C-10 in NC
No problem...just let me know.
#1321 |
Re: 1963 C-10 in NC
Thanks guys.
Got the pass side inner door stripped down last night. Ran out of light for pics, but ready to start repair work tonight on it. Helped Austin get the glove box reassembled on his truck and it was dark. Pics tonight.
#1322 |
![]() Join Date: Mar 2013
Re: 1963 C-10 in NC
Looks good! I think its salty enough though....
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#1323 |
Re: 1963 C-10 in NC
haha....gotcha.
#1324 |
Re: 1963 C-10 in NC
Ran out of light again, but started door repair on the dents and dings. Will have it all knocked out this weekend. If the rain hits as expected....I'll be going to engine & trans mounts, and the new headers that have been put off to do the cab prep.
#1325 |
Re: 1963 C-10 in NC
Also ordered the new seals for the window vent assemblies from Precision gasket. Part # VWK-111060
