front end swap
I apologize if thie pics dont show up. Im swapping the front cross member from a 1976 c-20 to a 1966 c-20. there is a differance between the idler arms 1st pic is of the 66 and the 2nd pic is of the 76. Just wondering if I should use the 76 assembly and drill holes in the frame or use the 66 idler arm, I dont know if it will bolt up or not.
![]() Join Date: Jan 2011
Re: front end swap
When I did the swap in my 65 I made a template off the 83 frame and put it on the 65. Clamped the idler to the template and drilled right through it.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
60-66 Nut
Re: front end swap
I always recommend using the later model steering linkage including the idler arm. The way PGSigns said works well. You can also wait until you get the steering box mounted and then just make sure the draglink is parallel to the crossmember. On other words, the same distance forward of the crossmember as well as below the frame, on both the drivers and passenger sides.
