Old 09-07-2014, 10:10 PM   #1
zach_carver
zach_carver's Avatar
65 C10 tire scrubbing HELP???
Ok guys need some advice I have bought a c10 that had springs heated to lower has P255/70R15 tires. Now problem is my left rear tire is scrubbing the front part of the bed. The right side of the truck has LOTS of clearance. I've removed all wood from the bed due to someone half way installing it all and they also used plywood in it. So all that is removed so I could see if bed was installed incorrectly. I'm not one to half way do anything and this is driving me crazy it only scrubs with the truck is unlevel or going thru a sharp curve like. Any help would be much appreciated. We've had multiple c10s dad says he's had a few 64-66 that the gap was always a little different but never this bad.
zach_carver is offline   Reply With Quote
Old 09-08-2014, 07:18 AM   #2
PGSigns
PGSigns's Avatar
Re: 65 C10 tire scrubbing HELP???
Post some pictures up. There was on on here like that a while back and he had a trailing arm badly rusted and folding up.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-08-2014, 08:02 AM   #3
Clyde65
Clyde65's Avatar
you have the springs heated and the pan hard bar is moving the rear closer tto the one side.
My suggestion is get rid of those heated springs, buy you some drop springs and an adjustable pan hard bar.
Problem solved for under $150.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-08-2014, 11:56 AM   #4
LVPhotos
LVPhotos's Avatar
New springs and adjustable panhard bar. The Lower you go the more the trailing arms push the axle up and to the front of the bed. I learned that the block could help some of this dropping the arms down for less push forward.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 09-08-2014, 01:18 PM   #5
zach_carver
will post pics this evening. will just the adjustable bar help any? i plan to bag in the near future just not right now $$$. so i hate to buy springs that will be removed. but mine looks alot like the one above in picture.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
Old 09-08-2014, 03:43 PM   #6
rickywideglide
rickywideglide's Avatar
i thought rear gets pushed towards right side when lowered?
rickywideglide is offline   Reply With Quote
Old 09-08-2014, 06:32 PM   #7
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I think your right, but an adjustable panhard bar should correct it. I had a similar issue before I got a tire rub.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-08-2014, 10:40 PM   #8
zach_carver
Ok I haven't been able to get any pictures yet. Sorry. But if y'all believe the pan hard bar will be a good first thing to try then what do y'all recommend cpp adjustable deluxe bar or early classic bar? I'm fairly new at this but would like to do it correct first time around. And would like to do parts that will allow me to lower more in future either static or bagged. Or are there any other brands yall would suggest? I will be doing all install myself so trying to keep it fabrication free. I know springs are needed also but like stated before I'm planing to bag hopefully in future and a cnotch but trying to do small steps at a time. And trying to acquire some white walls also.
Old 09-08-2014, 11:45 PM   #9
rickywideglide
i plan on using cpp panhard bar once my rear end is all back together,had similar problem with my tire rubbing left side,turned out to be trailing arm
Old 09-09-2014, 05:07 AM   #10
luvbowties
luvbowties's Avatar
Smile Re: 65 C10 tire scrubbing HELP???
I've never tried this, but could you just space the left trailing arm backwards/longer (at front where it bolts up), temporarily, to move the left end of the differential backwards? Easily reversed when you bag it.
Just reading, it sounds like rear end has been 'twisted'. A quick verification would be to measure the wheelbase on each side and compare.
Sam
luvbowties is offline   Reply With Quote
Old 09-09-2014, 06:29 AM   #11
zach_carver
Sam
We've tried that but every way we can measure the wheelbase it's very close from side to side. Cause that was my first option.
Old 09-09-2014, 12:04 PM   #12
LVPhotos
LVPhotos's Avatar
I have a adjustable bar I took off and stock 62 mount. If I remember right it is 33.5 eye to eye.
Old 09-09-2014, 02:56 PM   #13
Clyde65
Clyde65's Avatar
any play in the trailing arm mounts? I had one parts truck that the rivets for those mounts were pulled and it just took some new bolts and a lot of swearing.
Clyde65
Rebuild of Clyde
support our troops!
Old 09-09-2014, 10:01 PM   #14
zach_carver
No I've not been able to notice any play in trailing arms. But I'm not also real sure best way to check them for slack?
Old 09-11-2014, 08:22 AM   #15
Clyde65
Clyde65's Avatar
put it up on a lift and look at the TA mounts on the crossmember. Mine were TOTALLY obvious that a problem existed.
Clyde65
Rebuild of Clyde
support our troops!
Old 09-11-2014, 09:07 AM   #16
nsb29
nsb29's Avatar
if its scrubbing the left side its not your track bar unless it was over shortened the track bar moves the differential forward or backward very very little I would measure from a given point on the front of the frame to the differential on each side
nsb29 is offline   Reply With Quote
Old 09-11-2014, 04:22 PM   #17
Mackie
Mackie's Avatar
Reference off the frame rails and measure to the wheel rim on each side. If you see it's tighter on the pass. side then you need an adjustable (shorter) track bar.
Mackie is offline   Reply With Quote
