Old 09-07-2014, 04:39 PM   #1
UKNOWME
UKNOWME's Avatar
What should I do with this???
These gauges were in my Jimmy when I traded for it. It's not the gauges I dislike but the horrible panel they are mounted to. I'd swap back to a regular cluster but all the ends have been cut. Any ideas what to use so it's more appealing? Thanks for your advice.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 09-07-2014, 04:55 PM   #2
Car'n'Guitars
Car'n'Guitars's Avatar
Re: What should I do with this???
Fabricate new tabs?
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 09-07-2014, 04:56 PM   #3
jraymer
Could you fit those gauges into a stock surround, that way you won't have to mess with the wiring? Oops, not sure if you meant wiring ends or mounting ends.
1982 Chevy K20 long bed step
2002 gmc 2500hd dmax
jraymer is offline   Reply With Quote
Old 09-07-2014, 05:04 PM   #4
UKNOWME
UKNOWME's Avatar
I don't know. Will they fit? I meant wiring ends to the cluster.
1964 Chevy c10
Old 09-07-2014, 05:07 PM   #5
Car'n'Guitars
Then ignore my post.
Old 09-07-2014, 05:34 PM   #6
bdiamond
You could dig up a new harness and install it or just solder new ends on.
bdiamond is offline   Reply With Quote
Old 09-07-2014, 05:34 PM   #7
jraymer
Looks like they may fit with a little modification to the trim piece or the gauges. Here is a link I found that shows one done, just not sure the size of your gauges. http://www.fourwheeler.com/how-to/12...ck-chevy-dash/
Old 09-07-2014, 05:44 PM   #8
UKNOWME
UKNOWME's Avatar
Yeah that's more of the look I'd want if I keep em, thanks!
1964 Chevy c10
Old 09-07-2014, 05:45 PM   #9
UKNOWME
UKNOWME's Avatar
That may be an option too since I'll probably go to a salvage yard to get the trim bezel.
1964 Chevy c10
Old 09-08-2014, 03:17 AM   #10
andrewmp6
Depending the gauge sizes http://www.73-87.com/7387garage/inte...s_recessed.htm http://www.73-87.com/7387garage/inte...ge_surface.htm
Old 09-08-2014, 03:21 PM   #11
UKNOWME
UKNOWME's Avatar
Wow that 2nd one would be perfect IMO. Thanks for your efforts!
1964 Chevy c10
Old 09-08-2014, 04:25 PM   #12
johnwaynejeep
If you want to og back to factory, you'll need a new instrument cluster housing with the gauges you currently have, you may have to order a new printed circuit for the back of the cluster. You'll need a new dash bezel and take the in cab wiring harness from the donor truck you got the instrument cluster from, mainly you'll just need the plug that goes into the back of the cluster. You'll have to trace the gauge pins from the circuit board to the position on the cluster pin and then splice that line from your current setup to the correct pin on the cluster plug.
I think you may be better off trying to make your current gauges fit into the stock bezel slots or do a custom job like Andrew said, it'll probably be easier then resetting it to factory.
Robert
1975 C10 - Huckleberry
2007 Jeep JK - John Wayne Jeep
Smittybilt front/rear bumper, 10K winch
Pacific Grove, CA
johnwaynejeep is offline   Reply With Quote
