#51 |
![]() Join Date: Apr 2012
Re: Project "DV8ED" 67 Chevy SWB
Nice clearance.
Chad 1967 Chevy C10 "Project DV8ED" 1994 Nissan 300zx convertible 2004 Chevy 2500HD crew cab 4x4 |
#52 |
Cpp modular 2 inch drop spindles and 73-87 disk brakes.
#53 |
Put on some old roll around wheels and tires.
#54 |
Last one. After the install I can't express enough how great a product Porterbuilt has come out with. The installation was absolutely trouble free. Everything lined up and if you follow the instructions it's pretty simple.
Only thing left to do is clearance the rack and pinion and bolt it up.
Chad 1967 Chevy C10 "Project DV8ED" 1994 Nissan 300zx convertible 2004 Chevy 2500HD crew cab 4x4 Last edited by resto newbie; 09-10-2014 at 12:05 AM. |
#55 |
Looks good buddy!
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
#57 |
Thanks guys!
#58 |
#59 |
That's what we have to tell ourselves to keep our minds on the project I guess.
#60 |
For at least the third time I have decided on my wheels. They are Foose Knuckle 22x9 fronts and 22x12 rears.
#61 |
![]() Join Date: Jul 2009
Do they make a good wide 22" tire for that 12" wide wheel? The wheel is sexy, btw.
#62 | |
#63 |
Yeah, a grand would be painful to toast. I have a 295/30r22 on a 22x10 but a bit more aspect ratio than the 25 series...that is LOW profile for sure.
#64 |
35 would be perfect for the sidewall and diameter I want, and 305/series would be perfect for the width, but they don't make them.
#65 |
Love the choice in wheel. Let's see how long you stick with it lol!
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
#66 |
![]() Join Date: Apr 2010
Hey chad,
Pirelli makes a 335/25/22 and a 315/25/22 in a "scorpion zero" for about $700-$750 for a pair. They are also available in the "p zero" but way more expensive. I had some 295/25/22's on some 10" wide intros before and they were stretched out. Wade |
#67 |
![]() Join Date: Dec 2006
Frame is looking good, if you want a little more sidewall, I know some people run a 305/40/22 on 22x12's and they are inexpensive.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#68 |
305/40r22 is a 31.5 inch diameter tire. These PB kits can only lay frame on a 30 inch tire, right?
#69 |
I'm not sure, you might want to check with Porterbuilt on that. I know N2billet runs a 285/40/22 on both Hazel and Tiffany and that is a 31" tall tire. Also check out the build thread on project Lumberjack, that truck is running a 305/40/22 rear tire with Porterbuilt Dropmembers.
#70 | |
#71 |
Link to quick description of Lumberjack with pic
http://67-72chevytrucks.com/vboard/s...40&postcount=4
#72 |
Keith, you have billet aluminum wheels, I have a question. Do they come just polished? Are they also clear coated? If not, what harm would there be to get them clear powder coated right when you get them?
#73 |
Resto my Intros which are billets came cleared if that helps you any.
#74 |
Excellent! Thanks. Good news.
#75 |
My Intros don't have a clear coat on them, just billet and a lot of polishing
