Old 01-17-2004, 08:12 PM   #1
krazy_texan
krazy_texan's Avatar
frame swap?
there is a 67 gmc cab and frame for sale on the parts board that i am interested in buying but before i buy it, i have a few quistions,
will my 71 chevy front clip bolt directly to the cab and frame?
I am wanting to basicaly take everything from my truck and put it on this frame i am not sure if there is a difference on GMCs and Chevys
He says it has a Dana 60 rear with leaf springs, should i keep that in or put my coil springs on it?
which is the better rearend, Dana or Eaton, both are 4.10s which one should i use?
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 01-17-2004, 08:54 PM   #2
Hutch
Hutch's Avatar
krazy_texan
There is quite a bit of difference in the way that the rear-ends and the springs are set-up.
I think that if you went with the leaf frame you would have to leave it intact, it would be quite a bit of work to change a leaf frame to a coil suspension or visa versa.
If you get a chance to look at them side by side you will see what I am talking about.
Take special note of the cross member where the trailing arms connect, and the width of the leaf spring frame above the rear end.
Also the rear ends for the coils spring rear will have different perch's for the spring’s mounts.
Not to say that it can't be done but usually in the case of coil or leafs you get the type you want and go from there.
As far as the front end it should work but you might have to do a little fabrication where it come to the core-support.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 01-17-2004, 09:12 PM   #3
Bryan68custom
my 68 was coil spring type I switched the entire frame from a 72 gmc with leafs I left the leafs under it because thats what I wanted everything else lined up perfect with no modifying
2004 Extended cab LS silverado
2001 Buick Lesabre
1968 Chevy Custom 10 LWB Anniversery model
2008 crew cab lt (rolling on dubs)
"The nice part about living in a small town is when you don't know what you're doing, someone else always does"
Bryan68custom is offline   Reply With Quote
