Old 09-10-2014, 10:10 AM   #1
Hugh Mongus
Dakota Digital VHX Gauges
Where did you guys mount the two push button switches? I also read a post from 2012 saying not to put the temp sender in the head due to inaccurate readings. Should I put it in the manifold?
Thank you!
-Jason
USN Retired
Hugh Mongus is offline   Reply With Quote
Old 09-10-2014, 11:04 AM   #2
leftybass209
leftybass209's Avatar
Re: Dakota Digital VHX Gauges
you will get a bunch of different responses for where to put the temp sensor. My logic is, the manifold is very rarely the part that gets warped or blows a gasket when your engine overheats, it's usually the heads and head gaskets, which are far more expensive to replace than a manifold, so why check it's temperature? I'm sure there are other logical arguments to be made, that it just one. As far as your gauges, while I don't have them myself, I have seen clean routing for switches under the lights and wipers switches, utilizing the stereo pull knobs if you have another sound option, in the ash tray, and underneath the lip of the dash.
leftybass209 is offline   Reply With Quote
Old 09-10-2014, 11:11 AM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
What I would do to be sure is call tech support at Dakota Digital and ask them where they recommend you place the temp sender.
As far as the two push button switches, I would believe that is a personal preference.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 09-10-2014, 01:55 PM   #4
Hart_Rod
Hart_Rod's Avatar
Thank you!
The gauges for the 67-72 have the buttons already mounted in the gauge panel. It's personal preference on mounting the temp sender. That's where GM mounted them on all of the new LS motors...
Hart_Rod is offline   Reply With Quote
Old 09-10-2014, 02:17 PM   #5
Hugh Mongus
My gauges came with two momentary switches that I believe are used to calibrate everything once installed. One side goes to the brain and the other side goes to ground. They are black plastic push button switches labeled SW1 and SW2.
I understand mounting the switches is personal preferences I was looking for recommendations. I had thought about mounting them under the bottom lip of the dash, but I really didn't want to drill holes.
-Jason
USN Retired
Old 09-10-2014, 02:55 PM   #6
Hart_Rod
Hart_Rod's Avatar
Mine came with the switches also, but you don't use them on the VHX setup. They are located in the center display...
Old 09-10-2014, 03:03 PM   #7
Hugh Mongus
I just got off the phone with their tech support. He said they are required to calibrate and setup the gauges once they are installed.
-Jason
USN Retired
Old 09-10-2014, 03:13 PM   #8
Hart_Rod
Hart_Rod's Avatar
That is correct, but you use the 3 buttons on the front to do that....
Old 09-10-2014, 03:20 PM   #9
Hart_Rod
Hart_Rod's Avatar
http://www.dakotadigital.com/PDF/VHX-67C-PU.PDF
Old 09-10-2014, 03:32 PM   #10
Hugh Mongus
Ok, I'll try it without them. I would rather not drill holes in anything if I can avoid it.
Thanks.
-Jason
USN Retired
Old 09-10-2014, 04:04 PM   #11
Hart_Rod
Hart_Rod's Avatar
Thanks.
The gauges come with a pigtail that plugs into the back of the display and then has 2 wires that you plug into the brain box (where the toggle switches used to plug in). There should be an instruction sheet in your package that shows how to wire it up.
Old 09-10-2014, 05:01 PM   #12
RManson
Use them to calibrate and set up the gauges, then tuck them back up into the wiring harness and tie them out of the way. They don't need to be "mounted" anywhere permanently.
RManson is offline   Reply With Quote
Old 09-10-2014, 08:24 PM   #13
Hugh Mongus
Thanks for this. You were right. I didnt need the other switches at all.
-Jason
USN Retired
Old 09-11-2014, 09:34 AM   #14
Hugh Mongus
-Jason
USN Retired
Old 09-11-2014, 09:40 AM   #15
Hart_Rod
Hart_Rod's Avatar
Nice. Do these have the blinker lights in the original location?
Old 09-11-2014, 09:41 AM   #16
Hart_Rod
Hart_Rod's Avatar
Old 09-11-2014, 09:52 AM   #17
Hugh Mongus
Yes. They look pretty good. I was a little disappointed because one of the black plastic pieces with the arrow cut out was tilted a little bit and the arrow points up slightly. There really isn't any way to straighten up since the whole unit is sealed.
Overall I think they are awesome. They were especially easy to install and setup.
-Jason
USN Retired
Old 09-11-2014, 10:54 AM   #18
Hart_Rod
Hart_Rod's Avatar
Did you talk to Dakota Digital about that?
Old 09-11-2014, 11:44 AM   #19
Hugh Mongus
I haven't yet. I just noticed it last night after I got them hooked up.
-Jason
USN Retired
Old 05-26-2015, 11:22 PM   #20
PipsC10
PipsC10's Avatar
I have the new set-up with the analog clock in the center. I had to mount the sw1 and sw2 buttons in order to scroll through the lcd display to switch the read outs from clock, tach, 0-60 time, 1/4 time etc.. I mounted them flush with the brace that goes under the steering column. They are tucked away where they cannot be seen but easily can be reached and the display switched while driving. Ill get a pic of them mounted tomorrow
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
Old 05-27-2015, 12:54 AM   #21
'68 Newtricks
'68 Newtricks's Avatar
ohhh that looks good, same color combo I got, except no clock.
Will be installed sooner or later
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 05-27-2015, 06:32 PM   #22
trkfrk
trkfrk's Avatar
I mounted mine on the bottom side of the dash using an existing hole. I took a piece of 1/4" aluminum flat bar and drilled my holes in it, see pic. They're easy to access and hidden.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 05-27-2015, 06:50 PM   #23
Jonlopes
Is it me or is it odd to have 2 digital clocks 6" from each other?
Nice looking set-up though.
1971 Cheyenne Big Block Longhorn
Jonlopes is offline   Reply With Quote
