Closed Thread
Old 09-10-2014, 03:35 PM   #1251
slepysal
slepysal's Avatar
Re: What did you do to your truck today part II.
I like it !
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline
Old 09-10-2014, 04:05 PM   #1252
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by 66Submarine View Post
Odd that it sometimes won't run over 4,300, but other times will go to 5,000. Does it hold 5,000? I guess you must have some intermittent ignition issue or something.
The GM 292 dyno chart actually ended at 4,200; the 250 chart went up to 4,400 (gross HP peaks were 4,000 and 4,200, respectively). I don't think there's any doubt one will wind up to there, I just meant that the internet seems to enjoy clips of people trying to drop valves or put rods through blocks.
I think it might have also been a coincidence earlier with mine seeming to float something @ 4,700; I wound it to 4,800 today checking something and didn't notice it. I really probably should quit acting like a tree fell on my head, though...
Non-OT content: I wound it to 4,800 while checking how it sounded after finally cobbling a turnout onto the exhaust from some scrap laying around. No more deafening drone! Much better...
I was in the middle of a burnout..so it didn't hold 5 grand...it was bouncing between 4700 and 5000 then we let off and floored it again..shifted at 5000 and off we go. lol! I think now I may have slightly bent something...the rocker arms toward the rear are making a little more noise then they use to....and the engine pops air out the exhaust like its gotta burned up valve. lol! Ah well...newly hotrodded rebuilt 292 will be in there in place of it shortly! But it won't quite be the same feel as a 47 year old 292 doing 5 grand. lol! Least I won't have to worry about an explosion...I hope.
TJ's Chevy is offline
Old 09-10-2014, 05:56 PM   #1253
Originally Posted by Anthony Fremont View Post
I made these bed rails this morning. Took me about an hour. Wasn't thinking and bought 8' lumber, should have gotten 10' stock so that it would hang past the end and I could have dog-eared the top pieces. I also had to finish nail them together instead of being able to use the expensive stainless carriage bolts that I bought. I'm going to make another set later with nicer wood. Without the stainless, these cost just over $20 to make. Used "furring strips" since they were rounded on the edges and rough cut cedar for the stakes.
Didn't really have a plan, just kind of threw it up there. I think it turned out alright though, considering. What think ye?
They add character to the truck!
Palf70Step is offline
Old 09-10-2014, 11:32 PM   #1254
LVPhotos
LVPhotos's Avatar
Cruise in, cruisin, and Sonic.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 09-11-2014, 12:46 AM   #1255
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Pulled I6 3 Speed And Guided Older Brother and Nephew On Putting 5.7 Vortec 350 Trans In Full MSD Auto Column, Drive Shaft Cut And A Lot of Work In 3 Days Runs Like a Top. Exhaust Shop Screwed Us Over! But Otherwise came out Sweet, my Bro was happy
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline
Old 09-11-2014, 08:47 AM   #1256
robber grin
Installed my low floor transmission cover that was trashed when I got the truck... looks a bit better now. PO had hacked the firewall area up good to make a 4 speed work so had to deal with that too. Sealed the pan with 3/8th's windshield butyl in the beaded groove of the cover and seam sealed it all when I got it bolted down.
Blessings ~ robber grin
robber grin is offline
Old 09-11-2014, 05:08 PM   #1257
Thefullgonzo
Ok, here I go.... Purchased a 78 rolling chassis to switch out the hacked up torsion front end on my 60 short wide... Going with a triangulated four link in the back, the 12 bolt off the 78 is a 3.42?, 2.5 drop spindles in the front. The power steering setup off the 78, brakes etc.. Any recommendations for a posi for the 12 bolt, or anything else I need to be aware of? Oh plus airbags...
Thefullgonzo is offline
Old 09-11-2014, 05:12 PM   #1258
Thefullgonzo
Here is the 78.
Old 09-11-2014, 06:06 PM   #1259
LVPhotos
LVPhotos's Avatar
Lost my 65 needs some torsion bar keys for patterns. So Don't chuck them.
LVPhotos is offline
Old 09-11-2014, 09:22 PM   #1260
TJ's Chevy
TJ's Chevy's Avatar
Got my new NOS spotlight!!!!!!!
Old 09-12-2014, 10:28 AM   #1261
schpeen
schpeen's Avatar
new Edelbrock air cleaner
schpeen is offline
Old 09-12-2014, 11:09 PM   #1262
66Submarine
66Submarine's Avatar
Huh, weird. It does sound like something decided it didn't like that, though! One of the reasons I try to not do stuff like that too often with tired stuff of unknown origin...probably still do it too much.
Back to the thread again, I drove mine 115 miles today to pick up some parts for my Impala.
I also repainted the hubcaps for a more OE appearance yesterday.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline
Old 09-12-2014, 11:40 PM   #1263
DLW
Took it from a low hump
To a high hump and slapped some paint down. Also removed tank and brackets. Did most of the work last weekend, finished it up today.
DLW is offline
Old 09-13-2014, 01:34 AM   #1264
VonDog
VonDog's Avatar
Looks SWEET man!!! Nice job! :metal
VonDog is offline
Old 09-13-2014, 01:11 PM   #1265
jbgroby
jbgroby's Avatar
Rigged up and installed my E-Brake Cable and handle.
jbgroby is offline
Old 09-13-2014, 05:05 PM   #1266
ChrisDollins
ChrisDollins's Avatar
Cool pic! Do you plan on changing your front wheels? Good looking pickup none the less.
Chris
ChrisDollins is offline
Old 09-13-2014, 05:23 PM   #1267
jbgroby
jbgroby's Avatar
Anybody know why the cab floor has that squarish pressed divot on the rear passenger side of the trans hump?
jbgroby is offline
Old 09-13-2014, 07:41 PM   #1268
LVPhotos
LVPhotos's Avatar
Chris
Waiting on more parts before the 5 lug Salt Flats get put on. Need bags, rack, brake booster, maybe column.
LVPhotos is offline
Old 09-13-2014, 07:47 PM   #1269
LVPhotos
LVPhotos's Avatar
Chris
LVPhotos is offline
Old 09-13-2014, 08:08 PM   #1270
scuderia
scuderia's Avatar
Got my OG wood bed cut to size (long bed to short) now just have to figure out how to drill some square holes on the ends I cut off
Thanks Boonedogs72 for busting out the old long bed in one piece!
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline
Old 09-13-2014, 08:30 PM   #1271
ChrisDollins
That will be nice! Love those brakes, and the rack will be nice. Should quicken up the steering quite a bit. So you're 5 in the back and 6 in the front? I'm just reverse lol. 5 in front 6 in rear.
Chris
Old 09-13-2014, 08:58 PM   #1272
scuderia
scuderia's Avatar
finally got an air cleaner on the beast (off a C60) hope there's room enough for the hood to close..
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline
Old 09-13-2014, 10:54 PM   #1273
jbgroby
jbgroby's Avatar
Anybody know why this was put in the floor of the truck?
jbgroby is offline
Old 09-14-2014, 07:35 AM   #1274
bj383ss
bj383ss's Avatar
I Don't know the answer to your question wondering myself. Mine had a hole I welded up. Your floor looks awesome man. I love how you didn't paint the hump bolts gives some added detail.
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline
Old 09-14-2014, 09:15 AM   #1275
JWheeler331
JWheeler331's Avatar
Been really busy with our truck the past few weeks. Yesterday I was able to get all the wood cut and mocked up. Now I need to decide on If I want to go with a clear polyurethane or a pecan stain/poly.
Also got new emblems put on. I have a question about that though. My originals had a red "10" with chrome background. My new ones that I ordered were red background and chrome "10". Which were right? It is possible that mine were wore down and the previous owner dressed them up so I don't know which was correct.
Also got the tailgate sprayed. A little while out in this heat has that paint dried in just a little while.
And just for a bonus pic the other day I got the grill support and bumper painted up.
Our 1965 Build
http://67-72chevytrucks.com/vboard/s...79#post6204879
JWheeler331 is offline
Closed Thread
