Old 09-11-2014, 10:11 AM   #51
FarmerSid
FarmerSid's Avatar
Re: 1952 Chevy Vette Roadmaster LT1 Farm Truck Build
Forgot my camera yesterday to post an update. I filled in the fresh air intake on the passenger side outer cowl as I plan on running a VA setup. Which one, I don't know yet. Door gaps were OK but spent hours and hours getting them better. A bit more work and they should be almost perfect. I have a bit more done on fixing the gaps since that picture below was taken.
Below is the crap inner to outer cowl piece. I had to cut and weld it multiple times to get it to fit the way I wanted it to fit.
More of the inner to outer cowl panel. I made some pieces with my new bead roller to match up with the beads on the inner cowl panel. They matched up close before..........NOT!
All welded up and epoxy primed. Ready for a final coating before it gets covered up never to be seen again for another 60 yrs.
Inside area coated with and ready to be covered up with the outer cowls.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 09-11-2014, 10:14 AM   #52
FarmerSid
FarmerSid's Avatar
A few more of correcting the door gaps.
C4 IFS & D44 IRS
5.3 HO L33
Old 09-11-2014, 01:25 PM   #53
_Ogre
_Ogre's Avatar
keep up the good work
nice progress on your cab resurrection, not bad for 2 summers work
out side the rustbelt most people don't understand what real rust is
though i have to admit i may have walked away from this floor
shop air compressor timer
Old 09-11-2014, 02:10 PM   #54
FarmerSid
FarmerSid's Avatar
Ya I didn't think the cab was that bad but it was fun doing the repairs. She's all new now!
C4 IFS & D44 IRS
5.3 HO L33
Old 09-11-2014, 07:43 PM   #55
oldman3
oldman3's Avatar
Looks great...Jim
oldman3 is offline   Reply With Quote
Old 09-11-2014, 08:38 PM   #56
FarmerSid
FarmerSid's Avatar
Did some smoothing on the outer cowl to firewall tonight and put the hood on for a test fit. Gonna do the passenger side tomorrow.
Hood fitted like I have read in the past. Fits better without the spring hinge but figured out a way to get it much better with the spring hinge. Loosen the main hinge, lift the hood up high and hold while someone tightens the bolts from inside the cab. Works so far. Rubber seal will determine final fit. Will still need more tweaking but now I know it will be close when final fit comes.
C4 IFS & D44 IRS
5.3 HO L33
Old 09-11-2014, 09:15 PM   #57
OrrieG
OrrieG's Avatar
Looking good, you are much more ambitious then I. If I do another one, first step will be a trip to AZ or CA to visit some members from here and pick up a rust free one to start, I am so over body work for now. but getting older and will probably forget how painful it was.....
Old 09-11-2014, 10:01 PM   #58
Advanced Design
Advanced Design's Avatar
Really nice quality work and a good example for the rest of us to aspire too!
Advanced Design is offline   Reply With Quote
Old 09-12-2014, 09:08 PM   #59
BIGglaSS
BIGglaSS's Avatar
Nice work! Subscribed. Waiting to see the C4 transplant.
BIGglaSS is offline   Reply With Quote
Old 09-13-2014, 04:33 PM   #60
68 Four on the Floor
68 Four on the Floor's Avatar
Cab looks great. I like the "gills" deleted on the cowl that's the way mine will be.
68 Four on the Floor is offline   Reply With Quote
Old 09-17-2014, 09:38 AM   #61
FarmerSid
FarmerSid's Avatar
Thanks all! I noticed last night that I still have to weld the three braces to the floor on the back panel. What if anything should I be putting in between the braces and rear panel? I don't think there should be metal to metal contact.
C4 IFS & D44 IRS
5.3 HO L33
Old 09-17-2014, 03:02 PM   #62
b.sharp
b.sharp's Avatar
same black card board looking material that is under the gas tank. to keep it from rubbing on the floor. Sorry don't know the name of it. Almost looks like thin rubber roofing material to me.
b.sharp is offline   Reply With Quote
Old 09-18-2014, 08:06 AM   #63
FarmerSid
FarmerSid's Avatar
Thanks sharp. There wasn't too much of anything left under my tank or on the back panel when I tore it apart. I appeared to be a thick tar paper like matting.
C4 IFS & D44 IRS
5.3 HO L33
Old 09-18-2014, 09:46 AM   #64
Maybe just some fatmat or some other brand of sound deadener. Any chance I can get your dimensions for your front crossmember?
Old 09-18-2014, 10:15 AM   #65
FarmerSid
FarmerSid's Avatar
I have to do a bit of metal repair on the lower drivers windshield area where the rubber seal goes. I got the old rusted area cut out and started making the repair patch last night. The shape came out really good. That's as far as I got. I should be able to final fit it and get it tacked in tonight.
68, I will see if I can put together some pdf's of what I made my templates out of.
C4 IFS & D44 IRS
5.3 HO L33
Old 09-19-2014, 11:46 PM   #66
That would be awesome Sid thank you
Old 09-20-2014, 05:29 PM   #67
FarmerSid
FarmerSid's Avatar
Need some help people. Would someone mind posting a close up picture of their windshield installed so I can see how much the rubber covers the opening on the outside. Reason I ask is I have some pitting on the outside lip that can be seen on the last few pictures posted above. I'm debating new metal but my sheet metal skills may not be up to the task.
Another thing I need all your opinions on. Should I fill in the pop up vent? Wondering if this will prevent me from installing a VA system.
Cheers!
C4 IFS & D44 IRS
5.3 HO L33
Old 09-21-2014, 03:17 PM   #68
solidaxel
solidaxel's Avatar
Not all W/S gaskets are the same size, but close enough for your app.
If you drive with the windows down that vent in the open position will equalize the air flow, you will like it !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-21-2014, 06:52 PM   #69
FarmerSid
FarmerSid's Avatar
Thanks solidaxel. I plan on ordering Steele window seals as I hear they fit and work the best. I'm 80% on filling the upper cowl vent in. Unless others convince me to leave it. Don't want any leaks. I do like driving with the windows down. Not a big AC guy. Like to have AC but only use it when it's way hot out.
Got my lower windshield area fixed today. Take a peak below.
C4 IFS & D44 IRS
5.3 HO L33
Old 09-21-2014, 06:59 PM   #70
oldman3
oldman3's Avatar
Sid, window area looks super, nice work...Jim
Old 09-21-2014, 07:05 PM   #71
solidaxel
solidaxel's Avatar
I have installed power vent motors from RockyHinge Co on all my AD's and a very simple addition, The cowl vent cuts down a lot of wind buffeting with the windows down at speed
LS 3 4L70E
Old 09-22-2014, 02:06 PM   #72
FarmerSid
FarmerSid's Avatar
Thanks Jim. Will look into The RockyHinge system solidaxel. Thanks for the info.
C4 IFS & D44 IRS
5.3 HO L33
Old 09-22-2014, 07:33 PM   #73
FarmerSid
FarmerSid's Avatar
RockyHinge has quite a bit of stuff! It's got my head a spin'in with idea's.
C4 IFS & D44 IRS
5.3 HO L33
Old 09-22-2014, 11:12 PM   #74
BlueJeep
BlueJeep's Avatar
I left my cowl vent and have vintage air too. I ended up making my own mounting brackets but that appears like it would be no big deal for you.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 09-23-2014, 07:10 PM   #75
Advanced Design
The window repair came out really nice!
Power cowl vent....gotta check into that.
