Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-11-2014, 06:37 PM   #1
Marv D
Registered Truck Offender
Marv D's Avatar
Why driveline angles are so important
Not news to many,, but this is a very COOL demonstration of what happens when the trans output shaft and differential input shaft are not perfectly parallel. Only makes sense that this HAS to cause serious traction problems.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-11-2014, 08:04 PM   #2
PGSigns
PGSigns's Avatar
Re: Why driveline angles are so important
That is a good demo. Couple places in there it surely needed a CV joint.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-12-2014, 01:21 AM   #3
Super73
Super73's Avatar
Definately a cool demo. Now the question.. how much pinion angle will get you in phase?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-12-2014, 07:16 AM   #4
PGSigns
PGSigns's Avatar
With a four link we ran them at zero in relation to the trans. We also set the drive line up to be as much of a straight line as we could. This in a drag car application presents the lowest amount of wasted energy in the drive line. In the old days with we would put a couple of degress down on the pinion so when the spring wrapped up and the traction bar pulled up tight the angle was as straight as we could get it.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 09-13-2014, 09:21 AM   #5
hotrod 80
mini truck racer
hotrod 80's Avatar
[QUOTE=PGSigns;6839955]With a four link we ran them at zero in relation to the trans. We also set the drive line up to be as much of a straight line as we could. This in a drag car application presents the lowest amount of wasted energy in the drive line. In the old days with we would put a couple of degress down on the pinion so when the spring wrapped up and the traction bar pulled up tight the angle was as straight as we could get it.
Jimmy[/
I wnt through this with the Luv and just did it on the S-10 Added 2 degrees to theS-10 with slappers. Stll think it is off. Very cool demo .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 09-13-2014, 03:45 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
+1 to this. We snapped a torque arm and sent our driveline angle somewhere between the moon and the pavement....
end results (pics coming soon) is most of the differential in the pan, and a lot of fixing to do.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-13-2014, 05:28 PM   #7
JJLT1
JJLT1's Avatar
excellent movie Marv, 5 stars..
JJ
71 SWB 360 Th400 4.56
JJLT1 is offline   Reply With Quote
