Old 09-12-2014, 11:59 AM   #1
briscuba
briscuba's Avatar
Carburetor fun: Rochester Vs. Edelbrock?
Hello,
Is the term carburetor fun an oxymoron? Anyways... for those carb experts out there. I have a 1970 402 BB / 400 TH tranny in my SWB C10. 95% sure its the factory BB that put out 310 HP. Truck has headers as well (no heat riser). The Rochester carb turned out to be a 1972, certainly part of the problem. I have beat my head against the wall repairing and rebuilding it. And, even though I bleed Chevy orange, I think I need to go to a performance Edelbrock - which will take away from the "stock" look which at one time seemed important. But a truck has gotta run right!
Any suggestions? Can anyone tell me if they are using an Edelbrock on their stock BB engine now, and happy with it? Which model is it?
Hope that's enough info. to get the thread started. You guys rock!!
1967 C10: My next project
1964 SS Impala Hardtop, low and slow
2007 Harley Street Glide .... When all else fails to start.
briscuba is offline   Reply With Quote
Old 09-12-2014, 12:14 PM   #2
Lee H
Lee H's Avatar
Re: Carburetor fun: Rochester Vs. Edelbrock?
70 VS 72 Q-Jet should not be an issue. I would weigh getting the Q-Jet professionally rebuilt (by a real professional like Ruggles or Murphy, not just a carb shop down the street) VS buying a new Edelbrock and the cost to convert (linkage, fuel line, air cleaner? manifold? etc). Both options will give you years of trouble free service.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-12-2014, 12:15 PM   #3
DjS71
I'm sure plenty are running an Edelbrock 750 on their BBs. $350 new w/electric choke. (+ intake & incidentals if you want to do it right, Here's a kit)
That said, I loved the QJ I had on my 275hp 327. Those beer can secondaries are so much fun when they're working correctly. If it we're me I'd look into having it rebuilt/calibrated by a pro for roughly the same or less than a new Eddy.
You'll get more different opinions on carbs than there are rocks in a river, this just happens to be mine.
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 09-12-2014, 12:19 PM   #4
Hugh Mongus
I tried two different Eddys and was not impressed. They are fine if performance isn't your goal. They feel more conservative to me than a Holley. I switched to a Holley Street Avenger and it was like night and day. This is my personal opinion.
-Jason
USN Retired
Hugh Mongus is offline   Reply With Quote
Old 09-12-2014, 12:28 PM   #5
Grumpy old man
Grumpy old man's Avatar
Use a Quadra jet they run 750 cfm but with the small primaries won't ruin your gas miliage and will run 310 hp stock all day long around town and nothing sounds like a quadra jet when those big secondaries open up The pontiac and buicks came with a quadra jet that would gulp 850 cfm with a little work and it runs the 496 BB up to 585 hp with no problem .
Old 09-12-2014, 12:42 PM   #6
Doug's68SS
The Q-jet will perform, there is a classic car drag racing class that requires that you run what came from the factory. That is why i had Cliffs performance build one for my BB I am putting in my truck. The build is cheaper than a New carb.
Doug's68SS is offline   Reply With Quote
Old 09-12-2014, 12:53 PM   #7
briscuba
briscuba's Avatar
I might add that I did in fact have my mechanic rebuild my QJ. He may not be a QJ professional, but a solid mechanic. It is my understanding, however, that when it comes to tuning in a QJ perfectly, one needs to find an expert. I saw Cliffs Performance..? I send it in, etc.?
Awesome help thus far...
Old 09-12-2014, 12:56 PM   #8
BRL
BRL's Avatar
Originally Posted by Grumpy old man View Post
...nothing sounds like a quadra jet when those big secondaries open up...
Ain't that the truth!
Running an Edelbrock 625 cfm. on my 350 SBC right now, and they're ok, but I sure miss that toilet flushing secondary sound when a Quadrajet opens up!
If you do go with a QJ, be sure that there is no leakage around the throttle shafts from long time usage.
BRL is offline   Reply With Quote
Old 09-12-2014, 12:57 PM   #9
engineer_gregh
engineer_gregh's Avatar
I've got a 71 with the original BB although its been rebuilt. I'm running an Edelbrock 750, Edelbrock intake and headers. The intake and carb were on the truck when I bought it. I would love to go back with an original intake and QJet. I've owned a lot of these truck and from my experience the QJet is much better. I've never owned a Holley but I would bet its a better carb than the Edelbrock. I would send that QJet to a good shop and have it professionally rebuilt and tuned for today's unleaded gas. Just my .02 cents.
engineer_gregh is offline   Reply With Quote
Old 09-12-2014, 01:09 PM   #10
geezer#99
geezer#99's Avatar
You guys think one quadrajet kickin' in the secondaries sounds good, you should hear two of them. Sounds kinda like a dual quad hemi.
Keep the quadrajet.
For the price of an eddy or holley conversion you can get a custom built one from smi.
https://www.smicarburetor.com/
And he's in Huntington Beach.
But one thing to remember. 9 times out of 10 it's not the carb. It's your timing set up.
Old 09-12-2014, 01:27 PM   #11
imjeff
imjeff's Avatar
My QJ runs my BBC DD just fine. A common problem they had was internal vacuum leaks. A pro will epoxy those plugs and give you back a very good carb. I believe there is a DVD and/or book that walks you step by step through it.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 09-12-2014, 02:08 PM   #12
leddzepp
Moderator
leddzepp's Avatar
Edelbrock 750 on my 402. Zero complaints, runs perfect. Doesn't matter what kind of carb you have, they all do the same thing when properly tuned and set up.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-12-2014, 04:15 PM   #13
no1udknow
no1udknow's Avatar
when I was younger my pops had a holly 850 on his sbc. Great carbs, so when I got my first chevelle, I talked to him about putting a holley on it and he told me to just let him tune my QJ, he was a master at tuning old carbs. This may sound silly but he used to put a glass of water on the cowl and tune the timing, dwell, and carb untill the water smoothed out. My 70 malibu ran like a dream after he tuned it.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 09-12-2014, 04:48 PM   #14
davepl
davepl's Avatar
An incorrectly calibrated QJet will be no worse than an incorrectly calibrated Edelbrock, and probably the Edelbrock will be worse since it's a "performance" carb that sacrifices driveability for performance (if there's a free lunch, I haven't found it).
Since there's no benefit to switching, get your QJet redone by Cliff Ruggles or Carb Connection (Kirkland, WA) or any other reputable QJet person. Just not yourself or the gas station around the corner. Either might work, but with carbs I'm willing to pay more to get it right. Makes or breaks the fun and character of the truck.
I still think someone should make an EFI unit inside a carb body with injectors and a step-up fuel pressure pump. You could feed it 7psi of fuel and 12V ignition and it'd do the rest. Make it for under a grand (if that's possible) and get rich slowly.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-06-2017, 02:19 AM   #15
SonomaComa
Awesome thread, although I am quite a bit late on it. Lots of great info here.
I now think I will have my Q-jet rebuilt instead of switching to Eddy or Holly. I just picked up a 1969 C-20 with a 350. I was told by the owner that their Father purchased it new and they had it for years. So it sounds like Q-jet is the way to go but why do so many peopke back away from rebuilding their own? Now a days with so many books and internet why shy away from it?
SonomaComa is offline   Reply With Quote
Old 04-06-2017, 03:27 AM   #16
DjS71
Give it a shot, people shy away because of the difference between book learnin' and On-the-job training. Fear of failure I guess? IDK, grab a kit and throw it in there. I might have a book around the garage you can have, I'm waist deep in an LS swap so I'll likely only ever use it to level out a table. Might take me a day or 3 to reply to a PM if you send one.
Old 04-06-2017, 06:22 AM   #17
52napco
Seems the consensus is keep the Qjet....Which im0 is the only way to go. I have all mine restored by Bob Stone in PA. It's the best $250 you'll ever spend. I've got several Edelbrock
I'll send you for free..... I personally have never had any luck with them.
52napco is offline   Reply With Quote
Old 04-06-2017, 07:14 AM   #18
They are all good carbs. If Quadrajets are a bad carb I wonder why Edelbrock offers a copy.
Comparisons are usually putting a 40+ year old Q-jet vs new Eldy. Faulty comparison from the get-go. I had an Edelbrock Q-jet copy (that came on it) on my '72 for 15 years. Never touched it. Did top end and put a Q-jet I had rebuilt by the local shop I've used for 30 years for at least 1/2 the cost of a new carb and am very very happy, just as I have always been with all the Q-jets on my other trucks.
GM built some of the best designed longest lasting trucks in 1967-1972. Nothing "needs" changed.
Old 04-06-2017, 07:27 AM   #19
palallin
One note: to get the optimum performance (in the general sense) out of the Q-jet, you really need to have the original set up for heat riser, choke, etc. Don't expect the system to perform as designed when you've tossed out many of its components.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 04-06-2017, 11:48 AM   #20
68is4me
68is4me's Avatar
I also vote quad, But before you get to crazy on the carb what is it doing, are you even sure it is a carb problem? Timing, vacuum leak, bad wires and plugs could all make you think the carb is bad. I would 1st get it nailed down to make sure that it is actually a carb problem.
But on a side note I did do the cliff ruggle's book and the kits from him. Rebuilt it myself but it does get rather expensive if you don't have all the tools to do it right, jewelers bits, vacuum gauges, small punches, small grinders and lots of patience. At least after buying all the correct tools I can build more if I have to.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 04-06-2017, 11:51 AM   #21
68is4me
68is4me's Avatar
Wow, just realized this is a 3yr old thread
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
Old 04-06-2017, 12:07 PM   #22
^^^ That's ok, it was brought back up by another member yesterday with the same question. You are now talking to him and not the OP
Old 04-06-2017, 12:10 PM   #23
slikside
slikside's Avatar
Old thread, yes...but good discussion never dies out!
One thing to keep the in mind when going Q-jet, especially if you don't already have one....the later the model, the better. They were being revised pretty much right until they were discontinued (early-mid'80's).
I have a '72 C-10, that I thought had the original carb, but was pleasantly surprised to find on the rebuild that it had a julian date late in '76. It's been a while since, and can't recall exactly what the improvements were, but I recall that point from Ruggles book.
Also, you get what you pay for ina rebuild kit. Go with one from ruggles, or other Q-jet expert.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 04-06-2017, 12:50 PM   #24
69 MOD
69 MOD's Avatar
Another vote for the Q-Jet
The main problem is the throttle plate "butterfly" shafts get loose through the years and develop a vacuum leak.
Make sure the company you have repair the carb has the bushings installed before you put it back together or you will be chasing problems you don't know you have.
I've been lucky enough to have a good carb shop that has done my base plates for years, they'll even drill out my idle circuits if I ask to richen the low end.
Chad
'71 GMC 2500 Custom Ol Blue
'72 Custom Deluxe Highlander Stuffed Olive
'73 Trans Am
'13 Silverado 2500 Duramax Storm Trooper
69 MOD is offline   Reply With Quote
Old 04-06-2017, 08:24 PM   #25
Steeveedee
Who Changed This?
Steeveedee's Avatar
When you do go to rebuild your Q-Jet, get Cliff Ruggles' book, and get the rebuild kit from him, too. On my truck, the cam that lifts the metering rods on the secondaries broke (dropped down inside the well where it lives, not into the engine). His kit will have that cam, and a new float and accelerator pump diaphragm that resist ethanol. Best kit I ever bought. It even has a new secondary air valve spring, which can get old and not work as well. That MIGHT have been extra; its been a few years since I rebuilt mine. The truck starts and runs like a champ with the original carburetor. I took the throttle plate to a local carburetor guy to get the bushings for the throttle shaft. $50 got all four bushings (though putting bushings in the secondaries is kind of pointless). If you have the time, you can send your carb to Cliff. He has a long waiting list, though- last time I checked, it was a year- but that may have changed. If you give him the information on the engine, trans, etc., he can calibrate it for you. The thing is, with a carburetor that old, someone may have been into it, changing jets and metering rods, springs, etc. Cliff can make that all correct, or properly modify it for your application.
I guess you can tell which way I vote! I've had Edelbrocks and haven't been all that pleased with the longevity- they needed the throttle shafts repaired much sooner than my Q-Jet. That carb got the bushings at about 212,000 miles.
~Steven
Simi Valley, CA
