Closed Thread
Old 09-14-2014, 11:08 AM   #1276
cab_01
cab_01's Avatar
Re: What did you do to your truck today part II.
Got it tucked away while we are on vacation for 2 weeks. Should get it close to done the week we get back then it goes back to the painter for touch up. oh and yes the front will be dropped a little.
cab_01 is offline
Old 09-14-2014, 11:22 AM   #1277
TJ's Chevy
TJ's Chevy's Avatar
Nice looking truck!
TJ's Chevy is offline
Old 09-15-2014, 11:42 PM   #1278
bigdaddy64
bigdaddy64's Avatar
Truck is finally coming back together. Got my brakes finished and working. Next is painting the column and dash. Will be nice to drive the truck after taking it apart 6 years ago. The chrome valve covers are just temporary, going to replace them with Fabbed covers. 463 cubic inch Pontiac with a Lunati Vodoo cam.
66 c20 with 1/2 ton 73-87 front and rear suspension
2-1/2" drop spindles, air-bags, c-notch rear frame
463 Pontiac, SRP Pistons, Eagle Crank and Rods
Mega-Squirt Fuel Injection
bigdaddy64 is offline
Old 09-16-2014, 06:38 AM   #1279
64shortbox
64shortbox's Avatar
Got to love that Pontiac power and Kauffman aluminum heads to boot. Nice truck. Of course not only am I a Chevy C10 nut I also own a 1962 Pontiac Catalina, Ventura interior, 8 lugs, 4SPD and Tri-Power too. Not a factory Tri-Power car but that's what I want.
64shortbox is offline
Old 09-16-2014, 07:37 AM   #1280
PowerdbyChevy79
PowerdbyChevy79's Avatar
Originally Posted by DLW View Post
Took it from a low hump
To a high hump and slapped some paint down. Also removed tank and brackets. Did most of the work last weekend, finished it up today.
Looks good brother....what all did you have to change out for the high hump install....
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline
Old 09-16-2014, 04:01 PM   #1281
DLW
Thanks!
You need to cut out pretty much all the lower hump using that inside line you see and leaving that ~1.5" lip, I left a little extra metal and trimmed back with a grinder and fit checked constantly as I went. Then you need both parts of the high hump, the upper part gets spot welded to the firewall, then the lower bolt on high hump part gets installed, drill all the holes out, weld on new square nuts to the bottom of floor board. I also had to make a couple small panels to cover the stock shifter hole and trans brake hole in the bolt on high hump cover. then just some seam sealer and silicone to seal it all up.
DLW is offline
Old 09-16-2014, 06:42 PM   #1282
PowerdbyChevy79
Thanks!
Ok...seems easy enough...now I need to find me a high hump.....thx for the info brother..
1966 C10 "Mary"
Old 09-16-2014, 08:48 PM   #1283
ls60apache
got my roof skin stripped derusted applied some ospho now I need to sand and give it a coat of epoxy. while the skin is off im going to spray on some some sound deadener/insulation to the under side of roof skin and on the inner roof. then I will glue it in place.
ls60apache is offline
Old 09-17-2014, 12:08 AM   #1284
Softpatch
Softpatch's Avatar
Thank you for sharing I'm stuck on another truck deadline and can't work on reroofing my 63 C-20 be very interested in more pictures on how to the cab roof panel
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline
Old 09-17-2014, 12:11 AM   #1285
PowerdbyChevy79
Anybody got any advice or tips on a bbw conversion..im fixin to convert mine in a couple weeks...been doin some research so I figured I'd ask my fellow truck brothers
1966 C10 "Mary"
Old 09-17-2014, 09:00 AM   #1286
robber grin
They add character to the truck!
Hey Palf - Truck looks GOOD! She speaks to me...
Started the PS door repairs... Ordered the patch panels from Top Banana.
In rust we trust...yo.
rg
Last edited by robber grin; 09-17-2014 at 09:06 AM. Reason: Added text and photos.
robber grin is offline
Old 09-21-2014, 06:56 PM   #1287
62 Barnfind
62 Barnfind's Avatar
Put in a radio and speakers.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 09-21-2014, 09:02 PM   #1288
enamelplanet
enamelplanet's Avatar
Prepped and painted my dash.
64 Fleetside, Shortbox, BBW
66 Fleetside, Longbox, 4x4 SOLD
70 5.3, Fleetside, Shortbox
enamelplanet is offline
Old 09-21-2014, 09:07 PM   #1289
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
My pics of a photo shoot today
Here is todays shoot by me. The professionals pics will be a couple weeks
Alan's Classic is offline
Old 09-21-2014, 09:08 PM   #1290
DLW
Looks great..
Very Nice!
DLW is offline
Old 09-21-2014, 09:10 PM   #1291
DLW
Awesome photos!
DLW is offline
Old 09-21-2014, 09:18 PM   #1292
DLW
This weekend I got the dynamat put down in the cab, still need to do the doors.
Then the carpet came in Saturday via Fed Ex, bought from stock interiors and this is the plush carpet. It fit very well, pretty pleased with it.
Trimmed in.
Oh, and I also installed those Honda door seals, they fit sweet..
DLW is offline
Old 09-22-2014, 10:39 AM   #1293
JWheeler331
JWheeler331's Avatar
Well after realizing that I ordered the steel strips instead of the stainless I realized that I would have to paint my strips to keep them from rusting. I was going to go with a slightly darker "pecan" stain on the bed wood but with them being painted I liked the lighter wood so I went with a clear.
I had never done anything like this before and I know buying the kit may have been easier but this way was a lot cheaper and I do take some satisfaction in knowing that we did this all ourselves.
That said......glad to be done with the bed. That is a crap load of bolts to put in. I still have to do the bed to frame bolts and the very front row of bolts but other than that its done.
Our 1965 Build
http://67-72chevytrucks.com/vboard/s...79#post6204879
JWheeler331 is offline
Old 09-22-2014, 11:23 AM   #1294
Turtleman
Turtleman's Avatar
Great Job on the Bed JWheeler,
Looks Good!
Turtleman is offline
Old 09-22-2014, 11:27 AM   #1295
JWheeler331
Looks Good!
Thanks.
Our 1965 Build
Old 09-22-2014, 11:19 PM   #1296
Dillon Rock
I'd also like to know how it went. I need to do the upper skin on my 64. How did you remove the donor skin? Also what is the best method for doing that?
That's the thing about a Chevrolet, no matter how they look, whether it be a trailer queen or a good ol' used farm truck, no other truck on the road will always look that damn good wearing a Bowtie.
Dillon Rock is offline
Old 09-23-2014, 09:31 PM   #1297
ls60apache
hello I hadn't got a chance to prime and install the skin yet,but I cut the roof from the donor at the a and b pillars. when I removed the roof skin I used a spotweld cutter on the skin where it overhangs the w/s only because I also used the donor overhang also the green one in the photo.everywhere else I ground out the spot welds on the underside of the rain gutter to keep a complete flange around the skin.its a fairly simple but time consuming process.when the skin is loose be careful handling it, it is very flimsy especially around the front.good luck.
Old 09-24-2014, 01:02 AM   #1298
scuderia
scuderia's Avatar
continued on with my bed install... since i cut down a long bed i por-15'd all the edges and then went over them with some satin black. Also started drilling and filing the square holes I lost when cutting down the strips. Got the 9 at the front done so I was able to mount the front panel. I used some vinegar to remove the plating on the carriage bolt heads so they match all the originals now.. Couldn't quit for the day without propping up one of the bedsides to take a look. First time I've seen what my truck will look like with a bed
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline
Old 09-24-2014, 08:43 PM   #1299
scuderia
scuderia's Avatar
new window gaskets front and rear... also got to see the original color of my truck.. man that red fades something fierce. Glad it goes orange and not pink
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline
Old 09-24-2014, 08:51 PM   #1300
62 Barnfind
Nice Job!
John Z
62 Barnfind
Closed Thread
