Old 09-10-2014, 09:06 PM   #1
Tbruz
Rear tow hooks
Looking for a picture of installed stock rear tow hooks.
I picked up a set and will be installing them into my 72; would like to see how/where the factory installed them.
Thanks in advance
Tbruz
Tbruz is offline   Reply With Quote
Old 09-12-2014, 04:18 AM   #2
nobolt
nobolt's Avatar
Re: Rear tow hooks
I had these saved for reference, but am unsure if 100% correct. I suppose they would be great on a flat bed truck.
Dave
"... government even in its best state is but a necessary evil. Thomas Paine
"It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men)
nobolt is offline   Reply With Quote
Old 09-12-2014, 05:52 PM   #3
Tbruz
Re: Rear tow hooks
Nobolt,
Appreciate the pics, my frame doesn't look like that; I don't have that wedge shape on the bottom.
Any other opinions and pics welcomed
Tbruz
Old 09-12-2014, 06:11 PM   #4
nobolt
nobolt's Avatar
Re: Rear tow hooks
someone chime in on this...
I believe the wedge/triangle was added to accommodate the hook.
I think Pete (DeadheadNM) has these on his 4x4. I may have stolen the pics from his build.
Dave
Old 09-12-2014, 06:46 PM   #5
SS Tim
SS Tim's Avatar
Re: Rear tow hooks
The wedge was added for a mounting spot. Remeber the rearhooks were an accessory. Here is the only picture I have of the installation sheet showing them mounted on the side of the frame.
SS Tim is offline   Reply With Quote
Old 09-12-2014, 07:28 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Rear tow hooks
We added the wedges to accommodate the hooks on my K20. There is little clearance below the level of the rear bumper - mounted to the side of the frame would render these useless on a C/K 10/20/30 if a bumper is present so avoid that.
Old 09-12-2014, 11:52 PM   #7
Tbruz
Re: Rear tow hooks
SSTim,
Can you post a closer shot of the mounting instructions.
Tbruz
Old 09-13-2014, 05:07 AM   #8
SS Tim
SS Tim's Avatar
Re: Rear tow hooks
Originally Posted by DeadheadNM View Post
...mounted to the side of the frame would render these useless on a C/K 10/20/30 if a bumper is present ...
True enough but then rear bumpers were options or accessories too on pickups.
Originally Posted by Tbruz View Post
SSTim,
Tbruz
Like I said thats all of it. 400x300 pixles and 18.1KB
Old 09-13-2014, 10:14 AM   #9
Tbruz
Re: Rear tow hooks
Thank you
Old 09-14-2014, 09:16 AM   #10
Re: Rear tow hooks
They were an accessory,so people mounted them where ever they wanted
Old 09-14-2014, 12:03 PM   #11
Orange Crate
Orange Crate's Avatar
Re: Rear tow hooks
Contrary to mythical beliefs these hooks are not rare. You can still buy them from the original mfg AND the 2801 style would fit better on a frame rail, if you are so inclined to add hooks at the back. Put the 2801's in with some grade 8 hardware and add some doubler plates and never look back (no pun intended).
http://www.clevelandhardware.com/cat...g_devices.html
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 09-14-2014, 12:05 PM   #12
Orange Crate
Re: Rear tow hooks
edit to read 2801-A.....
Old 09-14-2014, 02:29 PM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Rear tow hooks
Huh - didn't realize these were still available, thanks.
Old 09-14-2014, 05:32 PM   #14
BLT gmc
Re: Rear tow hooks
Cleveland Hardware Part # 2801-C LH and RH Sales contact-Kathy@clevelandhardware.com They have a minimum order of $125. I had to order a total of 6 hooks 3 RH 3LH to make the minimum order of $125. Inexpensive. Good luck, Bruce
BLT gmc is offline   Reply With Quote
