Old 09-13-2014, 12:20 PM   #1
Benoist
Rear axle swapping
I have a Pickup 1958 305 V8 TH700
Rear tires 235/60/15
I want to swap a rear axle from a chevy car to match the bolt bolt pattern
I can get a Caprice 1979 axle (locking rear)
I using the truck on the on the highway 80 - 120 kilometers per hour
Is it a good axle or must i look for a other axle ?? (or is he too wide/gears not good......)
I live in the Nederlands so there are not many parts
thanks
Benoist is offline   Reply With Quote
Old 09-14-2014, 03:14 AM   #2
Nev68
Nev68's Avatar
Re: Rear axle swapping
thanks
What sort of rear end is in the truck now?
Nev
Need a bigger garage so I can keep more cool cars alive
My build, a long way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=595909
Nev68 is offline   Reply With Quote
Old 09-14-2014, 06:34 AM   #3
Benoist
Its is still the original truck rear axle from 1958
Old 09-14-2014, 07:55 AM   #4
Benoist
sorry it was original a 6cil Truck
Old 09-14-2014, 11:33 AM   #5
Dan in Pasadena
Dan in Pasadena's Avatar
Even though it was originally a 6 cylinder truck the rear end may or may not be original.
IF it is the original rear end (you must find out) it was most likely 4.11 or 4.56 final ratio and the Caprice rear end is not that low. It's almost certainly better for highway driving than what you have but you'll have to remove the rear cover on yours and count the ring & pinion gear teeth, and do the math to know for sure.
As for width? Just measure from wheel mounting flange to rear mounting flange on each to see how much wider the Caprice rear is than the one you already have.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 09-14-2014, 04:02 PM   #6
OrrieG
OrrieG's Avatar
here is the factory spec chart for rear ends. Ratios vary getting lower as the trucks get bigger.
Old 09-15-2014, 11:29 AM   #7
Benoist
I have the 3.90:1
Old 09-15-2014, 12:28 PM   #8
Highsider
Highsider's Avatar
And again (probably)...
What does Semi- and Full-Floating types indicate?
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 09-15-2014, 08:33 PM   #9
Roadkill58
Roadkill58's Avatar
You might consider a third gen Camaro rear.
I'm using one in my build.
Ogre has proven his setup on the Power Tours.
Rust Never Sleeps
Roadkill's 58 Chevy Stepside build
Roadkill's 69 Custom C20
Roadkill58 is offline   Reply With Quote
Old 09-15-2014, 10:31 PM   #10
Iceburgh
Iceburgh's Avatar
I think the caprice will be to wide
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 09-16-2014, 02:59 PM   #11
_Ogre
_Ogre's Avatar
as stated the caprice is too wide, any 82 to 92, 3rd gen camero/firebird/transam rearend is a sure fit
they come in a variety of options for disc/drum, gear ratio (2.73 to 3.73), open or posi
if you choose a 3rd gen check out the tag for gear ratio and also look here
120 kph is only 75 mph, truk has a 3.27 ratio and has no problem cruising ...
shop air compressor timer
Old 09-16-2014, 03:05 PM   #12
_Ogre
_Ogre's Avatar
lots of good info over on http://www.chevytrucks.org/tech/ifs&rearend.htm
scroll way down for rearend width info
Old 09-16-2014, 09:36 PM   #13
1958Warrior
1958Warrior's Avatar
1970-1979 Camaro, Pontiacs T/As and firebirds , as well as 1980-1992 third gen, Also S-10/ Bravada's 4x4 rear axle will have usually 3.42 gears, and later models have the disc brakes. Don't remember the exact widths but are all pretty close . I want to say
59-1/2"
1958Warrior is offline   Reply With Quote
Old 09-17-2014, 03:27 PM   #14
Benoist
59-1/2"
All to you thanks for the info
I go next Monday get the axle out of the truck and look for a axle on the junkyard and let you now
Old 09-19-2014, 11:27 AM   #15
greystoke
what is everyones opinion on an S10 Blazer rear end, I happen to have a nice one with 3.42 gears, posi and disc brakes. Would it work ok with a stock 5.3/4L60E?
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline   Reply With Quote
Old 09-20-2014, 12:18 PM   #16
_Ogre
_Ogre's Avatar
depends on what your putting it in and what it came out of
Old 09-24-2014, 02:08 AM   #17
Benoist
ok a small update
original axle from flank to flank (truck)
157.9 cm
i have a axle from a El Camino 1974
flank to flank 156 cm
and i have the
Cragar smoothie wheels (3135805)
15X8 5/4.75
OS=-6 BS=4.25 CB=3.19
not yet install but i let you now
Old 09-24-2014, 02:45 AM   #18
55dude
55dude's Avatar
bolt pattern will be different than front. toyota 4x4 is 6 lug. no chevrolet 1955 newer is 6 lug.
55dude is offline   Reply With Quote
Old 09-24-2014, 06:04 AM   #19
Benoist
o sorry the frond is a camaro clip
