Differences between grill filler panels for our year of trucks
Can some one explain the differences between the grill filler panels. I know the grill bolt holes are different. Is that all?
![]() Join Date: May 2007
Re: Differences between grill filler panels for our year of trucks
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
I am talking about the panel that the grill bolts to.
#4 | |
if you notice in some of the pic there are different grills on the same truck with out changing the panel the grill bolts to
I am going by what is available in replacement panels. They list one for 60-61, one for 62, one for 63, and one for 64-66.
hello! other than bolt hole differences for grilles the 60-62 had shallow notches where it fits over the frame rails. 63-66 the notches got a little deeper to clear the taller frame rails...I think also there were some differences in the baffling near the lower part of rad,but not certain on that.
double
That is what I am concerned about. I picked up a used one at a swap meet not realizing there was differences. Mine must be the earlier models because it is resting on the frame rails. My truck is a 66. I will have to get my old one down and look at it closer. I did once but I didn't look at the notches I was concerned about clearance for the light buckets.
grille mounting and headlight buckets wont be an issue but yes if you have a 60-62 panel on a 66 it will rub the frame rails. good luck.
Well I do have the early model. I am. Going to try and cut out the notches from my old grill shell and weld them on to the older shell. Much cheaper than buying a replacement.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
