Old 09-16-2014, 09:36 AM   #1
manimal
manimal's Avatar
2004 2500hd questions....
Hey everyone, I just bought a 2004 Chevy 2500hd std cab 2wd. It has some cosmetic issues and I need to find out what fits and what does not.
1) I need a passenger side door...manual windows/locks....what years are right for my truck? Will suburban doors work?
2) I need a passenger side rocker panel....where can I get the correct one and if I cut it from another truck, what will fit?
3) mirrors???? I have extendable tow mirrors now, the glass on the driver side is broken also is missing the trim plastic on the arms...again what years are interchangeable?
4) TOW HITCH...I NEED ONE.......is this an HD only item or will one from a std 1500/2500 work or even a 3500? and once again, what years fit?
5) last but not least, rear bumpers....are the rear bumpers all the same, but use different brackets??? I have a 1500 bumper on it now and it is about 2/3" too low......again(sorry) what years fit?
Thank You
Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 10-12-2014, 04:18 PM   #2
KEWLKATDADY
Re: 2004 2500hd questions....
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
KEWLKATDADY is offline   Reply With Quote
Old 10-13-2014, 08:43 PM   #3
P.K.
P.K.'s Avatar
On the mirrors for full size 99 - 07 classic I'm pretty sure all the mounting bases are the same.
For the rear bumper I'm guessing the 2500hd/3500hd brackets are different since the hd's have more space between the body and frame to clearance the Duramax Allison running gear.
Sorry, but I can't help you on the other stuff though.
P.K. is offline   Reply With Quote
Old 10-25-2014, 08:42 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
Rocker rust is very common in these models. You should see them in Minnesota after a couple of years. The rocker patch is an inexpensive way to fix your rust. It is extended cab sized but it can be cut down to Std Cab size. For those with rust into the sill area then you need either the slip-on rocker or the OE style rocker.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
