Old 09-15-2014, 06:09 PM   #1
66_c10_tpi
Differences between grill filler panels for our year of trucks
Can some one explain the differences between the grill filler panels. I know the grill bolt holes are different. Is that all?
66_c10_tpi is offline   Reply With Quote
Old 09-15-2014, 08:27 PM   #2
duallyjams
duallyjams's Avatar
Re: Differences between grill filler panels for our year of trucks
http://67-72chevytrucks.com/vboard/s...d.php?t=531285
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 09-15-2014, 09:57 PM   #3
66_c10_tpi
I am talking about the panel that the grill bolts to.
Old 09-16-2014, 07:58 PM   #4
duallyjams
duallyjams's Avatar
yes
if you notice in some of the pic there are different grills on the same truck with out changing the panel the grill bolts to
James
IG duallyjams
Old 09-16-2014, 09:49 PM   #5
66_c10_tpi
I am going by what is available in replacement panels. They list one for 60-61, one for 62, one for 63, and one for 64-66.
Old 09-16-2014, 10:00 PM   #6
ls60apache
hello! other than bolt hole differences for grilles the 60-62 had shallow notches where it fits over the frame rails. 63-66 the notches got a little deeper to clear the taller frame rails...I think also there were some differences in the baffling near the lower part of rad,but not certain on that.
ls60apache is offline   Reply With Quote
Old 09-16-2014, 10:07 PM   #7
ls60apache
double
Old 09-16-2014, 10:22 PM   #8
66_c10_tpi
That is what I am concerned about. I picked up a used one at a swap meet not realizing there was differences. Mine must be the earlier models because it is resting on the frame rails. My truck is a 66. I will have to get my old one down and look at it closer. I did once but I didn't look at the notches I was concerned about clearance for the light buckets.
Old 09-16-2014, 10:42 PM   #9
ls60apache
grille mounting and headlight buckets wont be an issue but yes if you have a 60-62 panel on a 66 it will rub the frame rails. good luck.
Old 09-17-2014, 06:59 PM   #10
66_c10_tpi
Well I do have the early model. I am. Going to try and cut out the notches from my old grill shell and weld them on to the older shell. Much cheaper than buying a replacement.
