Old 09-18-2014, 12:09 AM   #1
63c102013
63c102013's Avatar
Nv4500 question
I am working on 6bt nv4500 swap into a 63. I was wondering if anyone knew what I would need to make the electronic speedo drive mechanical so I can us the factory speedo.
63c102013 is offline   Reply With Quote
Old 09-18-2014, 07:32 AM   #2
ryanroo
ryanroo's Avatar
Re: Nv4500 question
pretty sure dakota digital has some conversion boxes to change an electronic signal to cable driven.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 09-18-2014, 11:00 AM   #3
dieseldude4bt
Re: Nv4500 question
Do you have a build thread?
We need pics of this project!
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 09-18-2014, 01:57 PM   #4
63c102013
63c102013's Avatar
Re: Nv4500 question
No I don't have a build thread started yet. Haven't had much time until now. Dakota gauges is a good site. I think I found what I need from there. Thanks for the help
Old 09-18-2014, 05:37 PM   #5
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Nv4500 question
If your NV4500 has an electric VSS sensor in it, remove it. Get a mechanical speedo drive assembly from a 727 trans and it should fit in there. PATC is them used and new with different tooth count to adjust for taller tires and different gear ratios.
Ryan
1969 Chevy milk truck
Old 09-19-2014, 12:05 AM   #6
63c102013
63c102013's Avatar
Re: Nv4500 question
Do you have to take apart the trans to change it?
Old 09-19-2014, 06:46 PM   #7
Dieselwrencher
Re: Nv4500 question
I do not believe so. The mechanical drive should go right in there. I can't say for sure as I haven't personally done it on a NV4500. But it has worked for a couple guys I know. They had a dodge trans too, not a chevy one. If they are different in this area, IDK for sure.
Ryan
Old 09-19-2014, 09:32 PM   #8
63c102013
63c102013's Avatar
Re: Nv4500 question
It's a dodge trans. I took the whole drivetrain out go 98
Old 09-20-2014, 10:32 AM   #9
notchbackgta
Re: Nv4500 question
I just bought this, but my truck isn't back together yet. I hope it works out as planned
I wish I had found this before I bought the Dakota cable drive, it was way more then I wanted to spend.
notchbackgta is offline   Reply With Quote
