How to tell if I have an HEI distributor?
Hi All,
First post here, but have been gathering great information from the forum. Love it. I recently bought a 71 C10 long-bed. I've been doing some projects on it. In researching on this forum about how to get my Temp gauge working, I've come across discussions about HEI distributors. Dumb question - how do I know if I've got one. It's a 350 with an Edelbrock carb. But what else should I look for determine? Thanks, Jeff |
Re: How to tell if I have an HEI distributor?
Google HEI, look at pics, then look at yours. HEI looks much bigger since the coil is in there, making the cap way bigger.
Or look for an external coil and a coil wire going to the top center of the cap. |
Welcome to the 67-72 Chevy Truck Board from West Michigan!
Attached is a picture of an HEI installed in a BBC. The distributors are the same as the SBC distributors. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Since we're talking about HEI, remember that a lot of us have robbed them out of mid-70s and 80s cars because even though they weren't great at high RPM, they were self-contained and pretty much bulletproof otherwise.
I like to point out, however, that the advance curve and the vacuum advance pot are, by definition, set up for a 70s or 80s smogmobile. How different that is in terms of total advance and when it comes in I'm not really sure, but it's probably worth checking if you're concerned about having that kind of thing correct.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
HEI comes in small cap with an external coil too
#6 | ||
"I ain't nobody, dork."
Yep... those came on TBI equipped vehicles. But I'm sure he's probably talking about large cap with the internal "coil in cap".
![]() Gary
Eat, Sleep, Drive a Chevy
Post a picture of your engine and we can let you know what you have!
Welcome to the board from Texas
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
Take the cap off and see if you have points and condensor in there.
Thanks for the help, guys. I'll take a closer look and post a picture. Appreciate the responses.
Here's what I'm looking at guys. What do you think is in there?
![]() Join Date: Apr 2010
That is a stock set up, not HEI
Thanks for the help, 70ShortFleet!
Now the next question - should i upgrade to HEI for more power, reliability, and ease of maintenance? |
#15 |
![]() Join Date: Mar 2012
oh yes, and do not tie into the existing wires , just run a heavy gage red wire from a Ingnition source from the fuse box to the distributor when you install it ,
make sure the fuse source only has power when the ignition is on Easy install,
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
#16 |
If you don't care about being stock original, then yes put one in!
#17 |
#18 |
Thanks guys. BigMac, lots of choices on Summit Racing. Have a favorite? I'm not looking to build a race engine, but a few more HP and smooth running would be great.
#19 |
http://www.summitracing.com/parts/msd-8360/reviews/
This one looks simple and solid. Any compatibility issues with the stock 350? |
#20 |
![]() Join Date: Oct 2009
You can also maintain your stock look with a stock cap by installing Pertronox in place of your points. Lots of info regarding Pertronix conversion on this site, explore before you buy HEI and decide that it's huge and hideous! Some think that. I'm on the fence - I prefer the stock look, but HEI is clearly a FAR superior system to points. That's why I usually go with Pertronix. Stock look, no points. Cool setup in my book.
http://www.summitracing.com/parts/pnx-1281/overview/ http://www.summitracing.com/parts/pnx-40011/overview/ Note these are the Flamethrower I systems - there is also a Flamethrower II that includes additional features. Good luck on your conversion! |
#21 |
I'm liking what I'm reading about the Pertronix conversion, Jocko. Might go that route. Seems simple and everybody has great feedback on it.
Do you notice a decent power increase? |
#22 | |
#23 | |
![]() Join Date: Aug 2014
#24 |
you won't notice a major change in performance with pertronix, but you will notice it doesn't degrade as new points wear to become old points, because there aren't any. You'll see a very minor increase in power, if combined with good quality plug wires, a pertronix hi-volt coil, along with the pertronix point replacement unit. It's nothing to write home about, but it is a great upgrade for maintainability. If you want to maintain any sort of stock look, I think it's the best/least expensive way to go. You need to pull the dizzy to install - I had a Pertronix I and had to shim the distro shaft. It's not always required, but it's required to check end play, otherwise timing will be erratic. (this problem is present with points also... it's just a smart thing to do). The shim(s) minimize end play in the distro shaft.
#25 | |
| Bookmarks |
| Tags |
| hei, hei conversion |
| Thread Tools | |
| Display Modes | |
