Old 09-19-2014, 07:55 PM   #26
dfrank
dfrank's Avatar
Re: How to tell if I have an HEI distributor?
Originally Posted by bigmac73 View Post
too much dizzy to try to set up for a new guy. he just learned the difference between a HEI and a Points style.
Good point.
dfrank is offline   Reply With Quote
Old 09-19-2014, 09:40 PM   #27
davepl
davepl's Avatar
Stick a Pertronix in a factory or repro small body housing. Even with a stock coil it'll be plenty for non-supercharged applications, particularly if you're under 11:1 compression, which I presume you must be.
I have the Ignitor III in my 402 and the Ignitor II in my 502, both are great. The III causes problems with some repro tachs, but I borrowed and then bought a unit that appears to work with the III as well (random luck,I think).
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-20-2014, 05:17 AM   #28
jjzepplin
jjzepplin's Avatar
I wouldn't underestimate him. He DOES own a 67-72 Chevy (71). This is just like learning anything else. Gotta start somewhere. When I put my first hei in my Chevelle I went for the Accel dizzy and full curve kit. Man what a difference. All I did was read instructions. I know-not really a manly thing to do but they were right there and in words that I understood and all so why not read them.
If it's running ok now then just do some reading up on the subject. Meanwhile drive your new truck til it starts acting up.
You will need new wires too so save this upgrade for the next tune up and you will be amazed.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-30-2016, 06:25 PM   #29
Moneymatt448
What's a good gap size and spark plug to run if I have hei distributor
Moneymatt448 is offline   Reply With Quote
Old 10-22-2018, 11:55 PM   #30
Christian Car
New to forums. I hope I'm doing this right. Im pretty sure I have an hei distributor. If I do, what gap should I put on my plugs? I've read that it ranges from .045 - .06 for an hei. Does that vary based on which hei distributor I have?
Christian Car is offline   Reply With Quote
Old 10-23-2018, 10:30 AM   #31
68 P.O.S.
The gap should be .045 for HEI. When HEI first came out the gap was .060, but was burning the tips of plugs, so GM changed it to .045
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
hei, hei conversion
