Old 09-20-2014, 07:47 PM   #1
IHutch5R
235 i6 help please!!
Finally got the 235 i6 in my 62' SWB running while I'm building the 350 I got for it. I may be brain farting here.. But I cannot find the throttle adjustment screw. I know them to be on the carb. Does anyone know where it's at, maybe a picture that shows. Thanks
IHutch5R is offline   Reply With Quote
Old 09-21-2014, 12:48 PM   #2
Budman56
Budman56's Avatar
Thumbs up Re: 235 i6 help please!!
I have attached a photo of a single barrel carb I dont know if you have the same but the throttle adjustment screw is in the red circle.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 09-21-2014, 01:05 PM   #3
IHutch5R
Yeah, sorry.. Rochester single barrel. That's the screw I've been turning. As soon as I do a half turn one way or the other it kills the motor. Any thoughts? Thanks
Old 09-21-2014, 01:34 PM   #4
ACK
ACK's Avatar
Are you adjusting with a vacuum gauge on it and have you adjusted your mixture, too? Has the carb been rebuilt in the resent past? Could be the mixture, a carb in need of a cleaning or rebuild, or combination of some or none of the above.
If you're not adjusting with a vacuum, I would start there. Check timing and all the stuff that goes with points, too, if you don't have a HEI distributor.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 09-21-2014, 02:15 PM   #5
IHutch5R
Did all that.. think I just figured it out. I cleaned the carb. And put things back the way they were. Just looked at a diagram of one and whoever rebuilt it before put things back the wrong way. So now they are right hopefully it'll work.
