Steering Box Ratio
I have a 64 C10 with stock power steering. It seems like it takes for ever turning the steering wheel to make a full turn. Can anyone tell me how many turns is standard on a power steering truck from center to lock?
Thank's Paul |
Re: Steering Box Ratio
I did a little more investigating tonight and discovered that from center it takes 3.25 turns to hit the stop when turning left. It takes only 2.25 to hit the stops when turning right. Is there an adjustment somewhere that I can do.
![]() Join Date: Aug 2008
Yes. You need to adjust the tie rod ends. The right needs to come in amd the left out. First center the pitman arm then adust the rod ends until the wheels are straight ahead. Then adjust the steering wheel.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
Also truck gearboxes have tall ratios. CPP and some other companies sell quick ratio gearboxes. Thats what I use and it is much better.
Ok it gets more interesting :
Is there some redneck engineering going on here look at the photos. It also looks like the fitting in the ram is cross threaded Can someone please post what this assembly is supposed to look like? Thank you. Last edited by Paul Mitch; 09-21-2014 at 05:47 PM. |
I guess I can only add one photo at a time
One More
![]() ![]() Join Date: Apr 2012
Heres what the hoses should look like. Yours were repaired. At one time these hoses were tough to get. Now just go to Rock Auto on-line and purchase them.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
It definitely looks like he soldered the line to the fitting
Thanks, I am going to order all new hoses.
Tags |
power steering, power steering upgrade, steering ratio |
