Old 09-22-2014, 10:15 PM   #1
Temple of Torque
72 Chev Tremec w/ZZ 454
Here are some pics I thought you may find helpful if your installing a Tremec TKO600 or ZZ454 into a 72 chev
Temple of Torque is offline   Reply With Quote
Old 09-22-2014, 10:22 PM   #2
Temple of Torque
Re: 72 Chev Tremec w/ZZ 454
Some additional pics.
Old 09-22-2014, 10:31 PM   #3
Temple of Torque
Okay so I had to:
-Cut the floor (although you may be able to slip it in without doing this. I did it to make things easier)
-Shorten the driveshaft (I had a 1330 yoke put on the driveshaft to match the 1330 slip yoke that goes in the transmission) I am still running a 2 piece driveshaft
-Drill new cross member mounting holes to support the tailshaft
-Clean off the paint on the bearing retainer hole for the scattershield so it would slide in properly
-Buy Ford plastic speedo drive gears to match my rear end ratio and tire size
-I also purchased the shifter, shifter knob, reverse light harness, and speedo drive adapter from American Powertrain
Other than that I would highly recommend the 5 speed. It works great and now I have the best of both worlds. Get up and go as well as hi-way driveability!
Old 09-22-2014, 10:37 PM   #4
Temple of Torque
More pics.
I also needed to change the clutch disk from a 10 spline to a 26.
Old 09-22-2014, 10:40 PM   #5
Temple of Torque
Floor patch
