Old 09-23-2014, 06:51 AM   #1
1972 Jimmy
1972 Jimmy's Avatar
Question on fastening of rear hardtop braket
Hey guys! I have a question on how the hard top mounting brackets are secured on the rear of the bed. What I’m not sure of, is how the lower bolt is fastened to the box side. Is there supposed to be a nut welded to the inside of the boxed area or is there a loose nut that is used??? I leaning to welding a nut to the inside of the boxed side but would like to know what is factory correct.
Thanks,
Eric
Name:  Rear top mount.JPG
1972 Jimmy is offline   Reply With Quote
Old 09-23-2014, 10:39 AM   #2
Sandtrap9072
Sandtrap9072's Avatar
Re: Question on fastening of rear hardtop braket
What does the left side look like? I'm running into the same issue. My left side has threads on the inside of the hole. But my right side has no threads.
Sandtrap9072 is offline   Reply With Quote
Old 09-23-2014, 11:18 AM   #3
pd1219
pd1219's Avatar
I believe there is a rivet nut there. Here is a link to youtube video about how to install them
pd1219 is offline   Reply With Quote
Old 09-23-2014, 11:34 AM   #4
briank
A lot of the times they pull out. I went to the hardware store and found an insert like what was there and welded it in
briank is offline   Reply With Quote
Old 09-23-2014, 11:44 AM   #5
1972 Jimmy
1972 Jimmy's Avatar
Mine is the same way!! The left side has some type of insert pressed into the bedside and the right side has nothing but a hole. The insert on the left side does not have any threads now. But I might have had threads at some point??
Old 09-23-2014, 01:00 PM   #6
richeilers
richeilers's Avatar
Originally Posted by pd1219 View Post
I believe there is a rivet nut there. Here is a link to youtube video about how to install them How to install a rivet nut (rivnut) and the tools you need - YouTube
Thanks for that advertisement!! lol.....8 mins and 8 secs of my life I'll never get back....
OEM was a nut welded back there, they usually break off at some point in their life.....
Rich
1971 Blazer 2wd CST 454 http://67-72chevytrucks.com/vboard/s...d.php?t=641414
richeilers is offline   Reply With Quote
