Old 09-24-2014, 05:18 PM   #1
kjolivier
kjolivier's Avatar
part time 2wd kit?
I bought a 66 4WD. It seems that it has an NP203 transfer case, but it also has lockout hubs from maybe a newer blazer. Hubs look like this:
From what I have researched this tcase is 5 different positions, and fulltime 4WD. It seems the hubs were added after, and that some have part time kits installed. Anyone know how to tell if mine has the kit? Is it as simple as watching the front driveshaft while driving? Any way to tell while it is in place?
kjolivier is offline   Reply With Quote
Old 09-24-2014, 05:31 PM   #2
LVPhotos
LVPhotos's Avatar
Re: part time 2wd kit?
The hubs are open/lock. The hub will spin without drive shaft unless locked. Less wear on drivetrain. Sorry you have to get out and lock before 4x4. No more shift on the fly 4x4. My 98 Durango had HD 203.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 09-24-2014, 10:50 PM   #3
kjolivier
kjolivier's Avatar
Just ordered one of these.
http://milemarker.com/products/drive...ts-accessories
Old 09-25-2014, 07:02 AM   #4
PGSigns
PGSigns's Avatar
Most of the time if the truck has locking hubs the 203 has been converted to part time. Shift pattern would look like this. (front)
4L
2L
N
2H
4H
(back)
Easy way to tell is to unlock the hubs and put it in 2H and you should be able to turn the drive shaft by hand. With the disc brakes and stuff on your truck it looks like you have 73 and up stuff under it. I was heavily into 4 wheel drive many years ago and racing mud trucks. We converted a bunch of them.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-25-2014, 10:36 AM   #5
kjolivier
kjolivier's Avatar
I got a hold of the previous owner and he knew nothing of it so I ordered one. Right now with the hubs unlocked the only shift position that the trucks moves is 4H Lock (5th position).
Old 09-25-2014, 10:36 AM   #6
kjolivier
kjolivier's Avatar
Also my truck doesn't have disc brakes. I wish it did, but I will likely be looking for an entire frontend.
Old 09-25-2014, 11:40 AM   #7
PGSigns
PGSigns's Avatar
Well the pic you have posted is disc brake, who's truck is that? If the truck will only move in 4H something is broke.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 09-25-2014, 11:40 AM   #8
PGSigns
PGSigns's Avatar
And the truck in the picture needs rotors bad.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 09-25-2014, 11:51 AM   #9
awbrown
My 77 chevy was a full time 4wd ,but some one had installed locking hubs on the front ,and if the front hubs were unlocked it had to be in 4L to move , that is because the 4h has to go through another differential in the transfer case.. 4L ( effectively locking the differential in the transfer case ) I used to be able to pull it back one notch (this is 20 years ago from memory ) on the fly and it would lock the transfer then instead of one tire spinning you had 2 tires spinning one front on back .. hope this makes sense ...
awbrown is offline   Reply With Quote
Old 09-25-2014, 12:29 PM   #10
kjolivier
kjolivier's Avatar
Jimmy
Wow, that was embarrassing. I bought the truck sight unseen, and was told it had drums F&R. I have had it for a month and hadn't taken that close of look. Hahahaha.
I am betting this whole frontend is from the 77 K5.
Old 09-25-2014, 02:04 PM   #11
PGSigns
PGSigns's Avatar
Well I think it is time to take a good look. I think the front is in need of some attention. Look all the brakes over and everything else under the truck. Make sure it is 100%.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
