Old 09-24-2014, 08:11 PM   #1
SCHRUMGMC
SCHRUMGMC's Avatar
Re-chroming truck parts
I'm planning on getting the turn signal lever re chromed to keep it original
and the chrome hubcaps
wondering how much it would be to re chrome my grille
Does anyone else get their things re-chromed?
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 09-24-2014, 08:59 PM   #2
_Ogre
_Ogre's Avatar
Re: Re-chroming truck parts
rechrome is usually a lot more expensive than buying pepop parts
especially on our trucks where it is a 5 yr cab and all the parts are repopped
rechrome is for vehicles that have hard to find parts
gmc grills are not repopped and you have no choice, but expect to pay 3 or 4 times what it cost for a new 59 chevy grill
shop air compressor timer
Old 09-24-2014, 09:09 PM   #3
SCHRUMGMC
SCHRUMGMC's Avatar
I'm trying to keep things original as possible.. Would it be cheaper to buy a new GMC hubcap or get the originals re-chromed
1971 GMC Sierra
1959 GMC 100
Old 09-24-2014, 09:14 PM   #4
71swb4x4
71swb4x4's Avatar
Cheaper to buy new. Check this thread out for an idea on prices: http://67-72chevytrucks.com/vboard/s...d.php?t=642552
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-25-2014, 01:34 PM   #5
_Ogre
_Ogre's Avatar
get it running before buying any parts to make it look nice
Old 09-25-2014, 05:33 PM   #6
SCHRUMGMC
SCHRUMGMC's Avatar
I'm buying two white walls for the back and getting the original rims redone so it'll have a little style
1971 GMC Sierra
1959 GMC 100
Old 09-26-2014, 11:25 AM   #7
Daze57
Daze57's Avatar
i agree with Ogre - i think you should get it in good running order first before you start gettin new parts for it .
it sound like you have had a difficult time getting it running - i think if you know a reputable shop or good mechanic - let em get that good ol truck hummin - sir i am not doubting your skills at all - i realize you have worked v v hard on that truck - sometimes it might be better to have a certified mechanic check it out - and then after your happy with it running --- then spend your money on gittin it just as you like it - and make your grandfather v v happy ( he prolly already is )
my so-called 02 cents worth
Daze57 is offline   Reply With Quote
Old 09-26-2014, 02:10 PM   #8
SCHRUMGMC
SCHRUMGMC's Avatar
Thank you Daze
I'm just planning ahead..
I am going to install a petronix ignition kit next week and a new vacuum advance.. to see if it will run better.. plus install a back up distributor
1971 GMC Sierra
1959 GMC 100
Old 09-26-2014, 03:11 PM   #9
OrrieG
OrrieG's Avatar
Installing distributor.
http://speedprint.com/deves50/doc/enginetiming.pdf
Make sure BEFORE your remove it the engine is at #1 cylinder top dead center with the rotor pointing at the #1 wire connector on the cap. Take a picture or make a detailed drawing of the distributor orientation to the block, you do not want to be a tooth off when you reinstall the new distributor. Then follow the instructions listed above. DO NOT turn the engine over until the new dist. is installed.
