Old 09-26-2014, 03:39 PM   #1
Gawdly
WTB: np205 shifter, BB power steering, etc
I am doing a big block and 700r4 swap on my 71 k10 and am still trying to track down a few parts.
I need the following:
- Shift lever, bolt, washer and short curved rod for a np205 transfer case. Bolt needs to be 9/16 thread. A lever from a th350/np205 setup should have the right bolt and parts.
- Big Block power steering pump, pulley, brackets and reservoir
- Clutch rod cover plate and screws for firewall
- Automatic pedal assembly
- Tall auto trans hump/cover
- Passenger rear cab frame mount. The big bracket that is riveted to the frame.
Please let me know if you have any of these and what you want for them shipped to 83709.
Gawdly is offline   Reply With Quote
Old 09-26-2014, 03:54 PM   #2
1rippen6
Re: WTB: np205 shifter, BB power steering, etc
I should have a few of those items I try and get a picture tonight.
1rippen6 is offline   Reply With Quote
Old 09-26-2014, 06:11 PM   #3
Desert Rat
Desert Rat's Avatar
I have a painted lever with bolt and washer, no short curve rod. Also have the tall auto hump cover. 125.00 shipped.
Desert Rat is offline   Reply With Quote
Old 09-26-2014, 07:30 PM   #4
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
BB PS Package w/pump pulley (less crank pulley): $175 shipped. Add $50 for crank PS pulley.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 09-26-2014, 07:32 PM   #5
teeitup
Just like to part out trucks!!
teeitup's Avatar
I have a AT brake pedal setup and clutch hole cover and I think I have the transfer case shift bolt
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 09-26-2014, 08:00 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I have a chrome 71-72 NP205 shifter to spare...not the attachment hardware though
Old 09-26-2014, 09:02 PM   #7
Gawdly
Is the hump cover is rust free and no issues? Is the bolt 9/16th thread?
Old 09-26-2014, 09:05 PM   #8
Gawdly
Does it come with the brackets, pump, pump pulley and reservoir?
I have a crank pulley coming from Desert Rat off an AC truck, is there an add on pulley I need? I thought it just ran off the crank pulley.
Old 09-26-2014, 09:07 PM   #9
Gawdly
How much for the pedal setup and the hole cover?
Old 09-26-2014, 09:23 PM   #10
1rippen6
I think I have everything but the shifter bolt and the BB ps parts. Everything is from a blazer so cab mounts and shifter I am not sure if they are correct and the s link is a flat bar my 71 is that way. Cab mounts from a 72 blazer. I took the picture of the throttle pedal thinking you needed that I have a better brake pedal assembly with the pad still on the pedal and I can get you a picture of that if needed. I also have the clutch block off plate but do not have it pictured. 225 shipped for everything.
Old 09-26-2014, 10:30 PM   #11
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Yes, it does come with the above items. There is a stand alone PS crank pulley and it is a little hard to find, because they usually go with the motors.
Phone: 360-956-7170
Old 09-26-2014, 10:45 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Are you parting with the K10's original motor and if so is it a 350? Thanks, Pete
Old 09-26-2014, 11:09 PM   #13
Gawdly
Huh... my 70 2wd w/396 (a conversion done before my time) has a BB truck power steering setup on it with reservoir and correct brackets and such but it runs right off the third (outer) ring on the crank pulley.
I'll take the power steering setup, skip the pulley for now. PM me with price and PayPal info please.
Thank You!
Old 09-26-2014, 11:10 PM   #14
Gawdly
It's a 307 out of god know's what. Ran good, not sure what I'm doing with it yet.
Old 09-26-2014, 11:12 PM   #15
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks for reply. Good luck with the build.
Old 09-26-2014, 11:14 PM   #16
Gawdly
Going to try and stick with painted lever... thank you though!
Old 09-26-2014, 11:16 PM   #17
Gawdly
Pedal setup in good shape? How much for it and the hole cover shipped to Boise 83709?
Old 09-26-2014, 11:19 PM   #18
Gawdly
I'll have to go look at my body mounts when I can get out to the shop tomorrow. I'll let you know...
Old 09-27-2014, 09:56 AM   #19
70STOVEBOLT
70STOVEBOLT's Avatar
Thank You!
The "third groove" is a separate, single groove pulley.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 09-27-2014, 10:12 AM   #20
teeitup
teeitup's Avatar
$42 shipped for at brake pedal and clutch cover plate. Thanks Randy
1980 chevy swb 4x4
Old 09-27-2014, 10:58 AM   #21
Gawdly
Sounds good. Please send me a pm with the item, price and your paypal info.
Old 09-27-2014, 11:04 AM   #22
Gawdly
Thank You!
Pickmup, my crank pulley is coming from desert rat. I've got a pm in to him asking how many rings are on it. I'll take the ps setup and possibly the pulley depending on what I hear from desert rat.
Old 09-27-2014, 11:06 AM   #23
Gawdly
Thanks for the info. I think the pulley on my 2wd is one piece but it may not be stock.
Old 09-27-2014, 04:56 PM   #24
teeitup
teeitup's Avatar
Here is the parts I told you about
1980 chevy swb 4x4
Old 09-27-2014, 05:05 PM   #25
Gawdly
Can you verify for me that the bolt is the 9/16 thread version? I guess there is a 7/16 version too (have one, doesn't fit). And the tall hump is auto 4x4 correct? look as good as the one 1rippen 6 posted? If so I'll take all of it for $125. Can you send it along with the pulleys I already bought?
