Old 09-28-2014, 05:41 PM   #126
solareclpse2000
Re: 1970 C20 long bed Duramax, Allison, on a 2003 4x4 chassis
This is a really nice build. I been following yours and wanab1tons threads and they are very informative. I have some questiins though. I have a 1993 gmc yukon GT I want to do this to. And a 2006 chevy 2500 reg cab long bed donor truck. Running 6.0 and eveything. Im looking at transfering everything, engine trans frame ect. I had planned the same frame work as you, by moving the axle forward and chopping the rear off. But, what was your target wheel base, hub center to hub center? I think I will have to do both techniques that you and wanab1ton used to shorten the frame. My wheelbase target is 112 inches, wheel hub center to hub center. So I may have to shorten it at the factory weld, and at the back, and still move the axle, gas tank, crossmembers. If you got the time and wouldnt mind can you take a measurement from hub to hub for me? Also any tips on how to ensure the axle is exactly true and straight after moving? My fear is if I move the axle and I make a mistake my axle will be cockeyed. Again, awsome build and amazing detail in your write up.
solareclpse2000 is offline   Reply With Quote
Old 09-28-2014, 09:15 PM   #127
widewhite70
widewhite70's Avatar
This is a great build with awesome attention to detail. Everything is looking great and this will be amazing when it's finished. Keep up the great work.
-Calvin
http://67-72chevytrucks.com/vboard/s...d.php?t=512270 my build, tube chassis and LS2
How I keep the truck shining, Detail thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=697902
widewhite70 is offline   Reply With Quote
Old 10-01-2014, 12:02 AM   #128
Lazzardkng
Originally Posted by rgunlock View Post
Your truck is really coming along and looking great! You'll be driving it in no time.
If you don't mind sharing, what are the actual paint colors/codes you ended up with? At least on the computer, that blue looks like one of the colors I've been considering for my truck - what I would call gunmetal blue. Looks great with the silver you chose.
Paint codes as requested
1970 Chevrolet + 2003 GMC Duramax 4x4 = Awesome
Lazzardkng is offline   Reply With Quote
Old 10-01-2014, 12:03 AM   #129
Lazzardkng
Attachment 1307599
Old 10-01-2014, 12:11 AM   #130
Lazzardkng
Installed all wiring, gauges, vintage air heat and ac unit and controls, and carpet.
Old 10-01-2014, 12:12 AM   #131
Lazzardkng
Attachment 1307607
Old 10-01-2014, 12:12 AM   #132
Lazzardkng
Old 10-01-2014, 12:13 AM   #133
Lazzardkng
Old 10-01-2014, 12:14 AM   #134
Lazzardkng
Old 10-01-2014, 12:15 AM   #135
Lazzardkng
Old 10-01-2014, 12:24 AM   #136
Lazzardkng
Installed banks inner cooler, banks EGT probe, radiator, trans cooler, hoses and inner cooler pipes, fan shrouds and adapted 1970 headlight buckets to mount on the 2003 radiator support.
Old 10-01-2014, 12:25 AM   #137
Lazzardkng
Red face Re: 1970 C20 long bed Duramax, Allison, on a 2003 4x4 chassis
Old 10-01-2014, 12:28 AM   #138
Lazzardkng
Old 10-01-2014, 12:30 AM   #139
Lazzardkng
Old 10-01-2014, 12:31 AM   #140
Lazzardkng
Old 10-01-2014, 12:32 AM   #141
Lazzardkng
Old 10-01-2014, 12:58 AM   #142
Lazzardkng
Lots and lots of block sanding primer
Old 10-01-2014, 01:03 AM   #143
Lazzardkng
Fit fenders, doors, and inner fenders
Inner fenders required extensive modification and shaping to accommodate the air box, coolant tank, battery, and fuse block
Old 10-01-2014, 01:17 AM   #144
Lazzardkng
Installed seats.
Seats are from 2003 silverado and jump seat is from 2010 silverado. Both were recovered in leather.Name:  image.jpg
Old 10-01-2014, 01:18 AM   #145
Lazzardkng
Old 10-01-2014, 01:18 AM   #146
Lazzardkng
Old 10-01-2014, 01:19 AM   #147
Lazzardkng
Old 10-01-2014, 01:26 AM   #148
Lazzardkng
Size:  71.6 KBTime for paint
Old 10-01-2014, 01:26 AM   #149
Lazzardkng
Old 10-01-2014, 01:27 AM   #150
Lazzardkng
