Old 09-29-2014, 09:11 AM   #1
87R10Coming
Will not start
I change my water pump and fan and now my truck will not start, it ran for a short while then it cut off and now it just turns over but will not fire
87R10Coming is offline   Reply With Quote
Old 09-29-2014, 11:04 AM   #2
johnwaynejeep
Re: Will not start
It sounds like you knocked a wire loose while changing the water pump. I don't believe the water pump or fan could cause a problem like that, even if incorrectly installed. If you put your belts in wrong you would get a squeel or just non-functioning accessories. I would start looking for disconnected wires that may have gotten bumped loose, especially if you have an electric fuel pump. Look around the battery and then work your way around to the back of the engine looking for things that are disconnected. I'm thinking electrical, but the vacuum lines on your CTO valves on top of the engine is a prime cadidate for this too, and in the perfect position to get bumped loose during a pump change.
Robert
1975 C10 - Huckleberry
2007 Jeep JK - John Wayne Jeep
Smittybilt front/rear bumper, 10K winch
Pacific Grove, CA
johnwaynejeep is offline   Reply With Quote
Old 10-01-2014, 06:11 PM   #3
87R10Coming
Re: Will not start
I check the wires and they all appear to be connected, I didn't hear the fuel pump turn on I just replaced it a year ago on the drivers side
Old 10-02-2014, 07:20 AM   #4
cadillac_al
Re: Will not start
Might as well check for fire. I have had ignition modules quit during unrelated mechanic work more than once.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-05-2014, 08:33 PM   #5
87R10Coming
Re: Will not start
I had a fuse blown it starts now but it idling rough
87 r10
