Old 09-30-2014, 06:06 PM   #1
SayBye
SayBye's Avatar
One step forward, two steps back. I6 No Start
after researching most of the day I came home ready to get started on my shift linkage, get home and go the start the truck and it cranks and cranks, but wont idle or run. I can put my foot on the gas, and it'll fire up and run while im feathering the gas, as soon as I let my foot off the gas, it doesn't idle, just dies.
I swear if its not one thing its another with this truck...
Shot a quick video to help yall get a better idea of what Im dealing with. The truck ran fine yesterday, however it may have ran out of gas or almost ran out of gas. I put three fresh gallons in it earlier. the sending unit is sending gas as it should be.
Any ideas would be awesome. Heres the vid:
https://www.youtube.com/watch?v=HOWi...ature=youtu.be
SayBye is offline   Reply With Quote
Old 09-30-2014, 06:37 PM   #2
64shortbed
64shortbed's Avatar
Re: One step forward, two steps back. I6 No Start
Stuck float??
64shortbed is offline   Reply With Quote
Old 09-30-2014, 07:53 PM   #3
T2vigil
T2vigil's Avatar
I too think it is a stuck float. But you could also check on a totally plugged filter. Keep us posted on the results. A rebuild kit would not hurt.
T2vigil is offline   Reply With Quote
Old 09-30-2014, 08:11 PM   #4
T and S
T and S's Avatar
Second plugged filter. If you ran it that low on gas probably sucked up a bunch of junk.
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 09-30-2014, 08:59 PM   #5
bullwinkle3331
I had a very similar situation recently with my '65 C20 with a 292. When I first got the truck I did the usual things.....Tune Up, Carb Rebuild, Fuel Pump Replace, etc.
Then one day I was low on gas and it started sputtering, then finally would not start....Put fresh gas in, rebuilt the Carb again, etc.
Finally took it to a shop that I deal with and found that the Distributor was worn out. They found it by adjusting the points, started it up and the points went out of adjustment again.....I mean way out. We put in a new Rebuilt Distributor and that took care of the problem.
This may not be your issue - but check the points and make sure that they are set correctly(static).
Just a thought from someone that recently was knocking his head against the walll.
Good Luck!
bullwinkle3331 is offline   Reply With Quote
Old 09-30-2014, 09:17 PM   #6
TJ's Chevy
TJ's Chevy's Avatar
One way would be to choke the engine....you should have a choke on that carb...sounds like its running way to lean causing it to starve for fuel...choking it would help richen the mixture and since you have to keep your foot on it that tells me yer float is no doubt stuck....take a hammer an tap the bowl of the carb....then try and crank it again. The tapping will help set the float free...also one of your jets may be clogged. Its something in the carb my man.
Old 10-01-2014, 12:49 AM   #7
66Submarine
66Submarine's Avatar
It seems like it tried to start when you held it wide open (0:45), but stopped when you worked the throttle and dumped more fuel in it (0:48), which would seem like flooding to me.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 10-01-2014, 02:12 PM   #8
SayBye
SayBye's Avatar
Here's another topic I might as well cover in this thread... I know my choke isn't hooked up and I have no idea how its sposed to look, whats there, what itsnt, etc. The PO had it off and I know he didn't install it back correctly....
A.) how's it susposed to look with the choke hooked up? what am I missing, etc.
B.) am I missing anything else on my carb? (took breather off for pics)
Old 10-01-2014, 03:13 PM   #9
ACK
ACK's Avatar
Below is a pic of how it should look. The spring on the throttle lever appears to not have any tension, see how it's at 12 o'clock on your carb and on mine it's around 6 o'clock. The choke position in my pick is how it sits with no choke. There's a lot of diagrams of the Rochester B on the internet and sites showing step by step how to rebuild, all good reference for how it should look. Good luck.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 10-03-2014, 05:59 PM   #10
luvbowties
luvbowties's Avatar
Smile Re: One step forward, two steps back. I6 No Start
SayBB, the pic in your lower right shows the choke completely closed, or "ON", only needed when cold starting, and then should be opened. Open the choke plate manually--it is flooding when it tries to start. You prolly need to push choke rod all way "IN" to open choke--may even need to temporarily remove the choke "wire/cable" at the carb until you get it running well. Then find a diagram & install choke cable & linkage correctly.
Your "22712 lever" looks to be on backwards (and maybe also upside down?? try both & see.) and needs repositioning such that your rpm-idle speed screw has something to screw 'against'--look at ACK's pic, for starters. Sorry cannot be more specific, but it's been awhile since I've worked on anything but 4-bbls.
HTH,
Sam
luvbowties is offline   Reply With Quote
Old 10-04-2014, 12:05 AM   #11
IHutch5R
I had the same problem you are having.. found the throttle lever sitting how yours was. Once that was corrected it would only start but not stay running. Getting that throttle lever right, setting the choke to where it opens and closes should get it running if your points are gapped right. Then once its running set your idle. Anytime I've adjusted my choke cable I've had to readjust my idle. Hope this helps!
IHutch5R is offline   Reply With Quote
Old 10-04-2014, 12:32 AM   #12
IHutch5R
Ack has a good pic of how it should look also.. here's how mine is. Just make sure the retention spring where the throttle lever mounts is on correct.
