Old 09-30-2014, 10:23 PM   #1
khan1369
khan1369's Avatar
Throttle body interchange from 90's Vortec to LS
While searching for a DBC throttle body I have noticed that the 90's MPI throttle bodies look amazing like a throttle body off of a DBC LS... can it be true? Are they interchangeable?
"Live, Love, Build cool s***"
Jesse Chapman, 2013
My Truck..
http://67-72chevytrucks.com/vboard/s...d.php?t=567219
khan1369 is offline   Reply With Quote
Old 10-01-2014, 11:02 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Throttle body interchange from 90's Vortec to LS
Well the throttle body on the big blocks were the same from 96-04, which would include the "ls" form of the 8.1l, so there is interchange in that sense.
There are also 3 and 4 bolt tb's for the LS motors depending on which one in which year, so if there is any interchange with the older stuff, it would be limited to certain years.
Sorry I can't answer the exact question verbatim, but the above is what I can put together.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-02-2014, 12:05 AM   #3
dayj1
As long as we're talking 3 bolt throttle bodies, the bolt patterns are the same. The biggest difference is that the 90s MPFI throttle bodies are made to mount pointing up like a carb. So, the cam on the side is clocked wrong for use pointing forward like all the "LS" throttle bodies. If you put the early TB on an LS intake, the throttle cable would have to come up from the bottom.
The IAC valve and TPS sensors are the same between the two types.
dayj1 is offline   Reply With Quote
