#201 | |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Attempting my first build 72 K5
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#202 | |
Yes I do. I'm going to need to save money anywhere I can now. I'm making a big change of plans to my build. Hint - I will have my own garage.. I'll wait to post pics before I fill everyone in.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
#203 |
2WD Jimmy
![]() Join Date: Mar 2005
If the clutch fan is good, you wont notice any real power loss. Make sure you use a good factory shroud.
#204 | |
I still have the factory shroud.. one of the clips is missing, most likely when I removed it must of fallen off and got kicked around somewhere
#205 |
Nice Blazer!
The quality of your work is top notch and you will have one of the nicest Blazers anywhere when you are done. |
#206 | |
I've decided I'm going to strip the K5 down completely and have it painted. Going all out with full restore.
#207 |
I've been busy and haven't posted in a while. I have quick update and will have more this upcoming weekend.
I moved into my new place that has it's own garage. First thing I'm doing is making it shop ready to fit the rolling chassis in while the body is at the body shop. I built this pulley system to hold the top above the garage door. I can walk underneath it without hitting my head. Gives me plenty of clearance
#208 |
I've made the decision to go all out. The body and panels will be stripped and painted Dark Olive, like the original.
I've made some progress in the disassembly process.
#209 |
more pics
#210 |
Your blazer looks really solid.
Keep up the good work.
#211 |
Carpe manana
Looks solid! Don't let the neighborhood assoc give you grief
![]() As for the door strikers, were these bolted into threads/nutserts that are somehow affixed to the pillar? On pickups there is a backing plate which will drop into the cab when the striker bolts are removed but not sure if K5's are the same. I have a fresh set of parkerized strikers I want to swap in but am afraid to drop the backing attachment (whatever it is) if loose then have to remove the rear panels etc. to retrieve them.
#212 |
Looking good, The body looks good already, she is going to be a stunner The hard top has an unusual metal receiver for top of window? .... also ( the radiator in the photo, looks like a replacement to me, not Original.)
#213 |
2WD Jimmy
Man that is a really nice tub. This is a very worthy candidate.
#214 | |
![]() What's the best way to tell if it's the original radiator? Is there serial number or something I could reference. If it's not the original, I might as well order a new one of those brass/metal ones that ClassicHeartbeat instead of spending just as much money restoring an aftermarket one
#215 | |
![]() I'll have to go home and check on the door strikers and get back to you on that.
#216 |
@Tom @notsolo @Gillnetter and Pete
Thanks a lot for the compliments. I have my ups and downs with this, but I love working on it and I just keep telling myself, when this is all done, I will have one sweet looking K5 that will last a lifetime.
#217 |
Updating with some more pics
Rims powder coated rally silver Cleaned up the hubs caps and rings Had the hub cap bolts Zinc plated Clear Went with the white letters facing outward
#218 |
Rear Axle powder coated (60% gloss black)
Had the Bolts Zinc plated Clear
#219 |
Carpe manana
Wow that looks great. I'm really digging the zinc coating.
#220 |
Looks like metal channel's on the hard top where the top of the window would fit. ( With window cranked up) never seen this before, maybe this is single wall top specific.
#221 |
I'm trying....
![]() Join Date: Oct 2013
Been following you since the start. I think it's awesome that you're going all the way....but those axle shots...Wow...they definitely deserve an attaboy!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#222 | |
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=13
#223 | |
I really like the 60% gloss black.. It's not to glossy and not too plain either. right in the middle. I read through your build. The body work you're having to deal with is impressive. I don't think I could take something like that on. Question - do the doors on our trucks separate or was this cut?
#224 |
I've noticed a lot of guys use these support bars between the door jams.
What does this do? Is this something I need to have since I have the doors off and all the other panels.. I'm close to removing the body from the frame
#225 |
The Tub is like a floppy noodle, the reinforcement bar holds the door opening strait as possible while repairs are done. Any welding that is needed will not interfere with the door closing correctly. Usually the bar is set when the top is on to insure correct alignment...... I think the pieces from LMC are rubber..I am about to glue the rubber door pieces to my hard top, same as the ones #15 in LMC cat- , I can get you a photo of them tomorrow.
